Question about Canon NP 6050 Copier
E0004 on Canon NP6050
I am getting an error code E0004 on my np6050 copier... what should i do.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
It is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Posted on Oct 24, 2007
SOURCE:
What is d51 error in np6050?
Try Start Control Panel Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
Apr 26, 2014 | Canon NP 6050 Copier
Error code : e030
http://printer1.blogspot.com/2008/11/canon-np6050-service-manual.html Above a service and repair manual, this will show you what to do.
"E030" Total copy counter problem.
May 06, 2010 | Canon NP 6050 Copier
I want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
Apr 09, 2010 | Canon NP 6050 Copier
NP6050 Codigo E400
E400RDF to copier communication problem
Recommend to apply to service.
Nov 02, 2009 | Canon NP 6050 Copier
Canon NP6050 E212 -lense problem
change the small gear located (inside in lens drive assambly motor)
Feb 02, 2009 | Canon NP 6551 Black and White Copier
Error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Dec 07, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
498 people viewed this question
Clive
Clive
old marine
old marine
