Question about Dell Inspiron 6400 Notebook
Blue screen corruption error
Dell Inspiron 6400, have re-install with Windows xp. Most of the times system restart the laptop with a blue screen suggestion hardware driver error.
Please advice how I can resolve the Blue screen corruption error
Most concern about the data on the system.please advice
Thank you
  • Anonymous Nov 02, 2007
    i buy dell inspiron 6400 model 5 month ago and they same problem what you saying that give more display error because i have no knowldge how to do to fix it i come here to report you pls kindly to fix this error thank you
You might want to reseat your ram, Also See if you can get past the BSOD by hitting F8 and getting into Safe mode with Networking. Once there paste this into a Internet browser:
Once downloaded and installed, click on
File>Symbol File Path > type "SRV*c:\debug_symbols*" and click OK. (nothing will happen)
File>Open Crash Dump>browse to c:\windows\minidump and select the file with the latest date. They are named in the mmddyy sequence.
Once the file is open wait and click on an option "!Analyze-V"
Then look for module name. This is the file causing the error.
Though lengthy, if done right this will certainly fix your issue.
Posted on Oct 25, 2007
  • 117 Answers
I think ram problem or another one os install
mostly its ram problem
Posted on Oct 24, 2007
I have dell inspiron 1764. Froze. Restarted, after loading from blue Dell Inspiron bar came up with screen saying operating system not found
Press key and the power button to initiate diagnostic testing on your laptop. You want to see if there are any hardware errors, specifically the hard drive. If all tests pass then your operating system software is corrupted and needs to be re-installed.
Sep 01, 2011 | Dell Inspiron 1764 Laptop - Windows® 7...
Dell XP restart problem
This error comes due to 1. RAM problem or 2.Hard disk problem or 3.Software/device driver problem or some times 4.Virus problem.
First you run the system in safe mode (pressing F8 at booting) - restore the system (start-programs - accessories - system tools - system restore). PC will be restarted and if it runs well then fine. If not again run in safe mode- uninstall few softwares or utilities, clear the temporary files, few drivers - restart the PC it may run well. If it does not run in safe mode the problem may be due to virus or critical RAM problem (main suspects, as the error may be for different reason). Now you format the hard disk and install your applications and drivers one by one and restart and check whether the problem repeats. Failure with the step you should change the RAM. With all failures - motherboard should be repaired and you have to give to the service center.
Jun 13, 2010 | Dell Inspiron 6400 Notebook
Giving blue screen with error message & getting stucked.
the blue screen also appears when there is a hardware malfunction. use ur BIOS to check whether all ur hardware are working fine
Feb 12, 2010 | Dell Inspiron 6400 Notebook
Blue screen on Dell Inspiron 6000 Laptop
OUCH... Might need a new harddrive or motherboard. Does it even let you go into the bios? Maybe you can do a full reinstall to save you the dough.
Jan 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Dell Laptop Inspiron 6400 - "Stop Error Screen" appearing
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
There are two ways,you might be able to fix it
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware).
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 6400 Notebook Logo
481 people viewed this question
Alun Cox
