Bissell Proheat Pro-Tech Mod #7901 Will not spray any liquid to the carpet and red cross indicator is not turning It is not spraying either the soap or water, replaced the belt. still not working. the only manual I have is the user manual - totally useless. What are the heads you clean with a toothbrush? Where can I get a good manual?
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and...
(More)
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and have no idea of what I am looking for
Bissell Proheat Plus Model 7901-P won't spray out cleaning solution, but does **** up liquids. What...
(More)
Bissell Proheat Plus Model 7901-P won't spray out cleaning solution, but does **** up liquids. What would cause this? Also, Lost Manual where can I get another?
it will not **** the water back up but it the suction is working on the base part below the water...
(More)
it will not **** the water back up but it the suction is working on the base part below the water canister
it'swork in reverse. The roller spins when it's upright and stop when yo relaease the foot tab. How...
(More)
it'swork in reverse. The roller spins when it's upright and stop when yo relaease the foot tab. How can I fix this?
7901 problem with no spray, pull trigger, but nothing comes out...pull out the bladder container,...
(More)
7901 problem with no spray, pull trigger, but nothing comes out...pull out the bladder container, how do I get to the water lines to unplug any clogs, (no cleaner solution comes out either.)
