Question about Westinghouse Washing Machines
Westinghouse laundromat 800 7kg washing machine does not spin?
Australian westinghouse laundromat 800 7 kg washing machine does not spin what could be wrong with it???
  • 209 Answers
SOURCE: Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Posted on Oct 07, 2007
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
needs new bearings our does the same
Posted on Aug 18, 2008
  • 41 Answers
SOURCE: Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Posted on Jan 09, 2010
  • 713 Answers
SOURCE: We have a Westinghouse Laundromat 800 (7Kg)that
Hi just read your posting.Now try this.Select only cold water fill and start cycle,then when you hear water entering your machine turn the power off at the wall.The water should stop filling straight away.If it does try the same test on your hot water.If either of the valves are faulty it should continue to fill after you have turned the power off to the machine.Please reply and tell me if the hot or cold water did not stop or if they both stopped.Please try the test on hot and cold a couple of times to be sure.Looking forward to your reply.
Posted on Jun 27, 2010
How do i reset cut out switch in model 1640m laundromatic
is ther not a reset button at back not fimilar with this mech but some have one
Feb 28, 2015 | Westinghouse Washing Machines
Electra 535 Dual Spin - I`m trying to discover what the capacity of this machine is, the manual supplied with the machine gives all spec.s apart from its size. ie is it 6, 6.5 or 7. kilos...
From what I remember, the 535 is a 5.5 kg machine. The best way to load any front loader is to have the tub full but not packed. Its the safest. As for weight capacity, due to Australian Standards testing, machines have to state what load they will handle with a certain volume of water and power usage, but any front loader, load it up but dont pack the clothes in and you will have the best efficiency. By the way, the clothes are measured dry weight..
Jul 31, 2011 | Hoover Washing Machines
Repair manual for a LT758S westinghouse washing machine
I have a Westinghouse LT758S 7.5 kg complete care washing machine everytime I turn my washing machine it will flash wash so I press start, it will beep 6 times and the medium and high lights will continue flashing on the water level??? I tried turning it on off but nothing what should I do?
Nov 20, 2010 | Washing Machines
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
0E Error
Apr 10, 2009 | Westinghouse L2046NV Monitor
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
Jun 03, 2008 | Washing Machines
Washing Machines Logo
170 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
