Question about Cell Phones
We 2 sony Ericssons both are failing to respond when you want to.
Failing to respond when you want to disconnect or hangup on a call, the screen goes blank and it continues with the call. It will not work by shutting it or push the disconnect button. If you power down during this problem the screen will flash on an off. It is like a computer when it locks up. Both phones are doing it. Are they just junk. Steve
  • 421 Answers
Sir it must be battrey problem
Posted on Jun 03, 2009
Phone lock code
Sir/Mam
Try this code and see whether it's helpful to you or not?
Older Ericssons *#0000# & Newer Ericssons <0000> & Also, pressing <8888> on the newer Ericssons changes the language to Automatic. < stands for left arrow button or joystick and > stands for right arrow button or joystick.
hanks for using FixYa!
Oct 08, 2012 | Sony Ericsson T650i Cellular Phone
Black lines running across the sony ericssons w580i screen
if only vertical or horizontal line across you LCD display
your LCD need to be replaced.
your LCD cannot be fix.
Mar 07, 2011 | Sony Ericsson W850i Cellular Phone
Imate, ultimate 8502, when i started to boot, hangup at "align screen" i already tapped the screen at 4 corners, but still hangup at align screen, so pls guide me what i have to do
imate, ultimate 8502, when i started to boot, hangup at "align screen"
Jan 02, 2011 | i-mate Ultimate 8502 Cell Phone
The sony ericsson g 502 is not switching on. When i charge it there is a dim light in the background. When charge is removed the light goes off. I have data cable. What should i do to get my mobile fixed
like so many Sony Ericssons, it has a tendency to switch itself off or to report errors such as "inactive sim card." You should inform it to costumer services
Dec 11, 2009 | Sony Ericsson G502 Cellular Phone
SONY KV32XBR400 (year 2000) screen is blank when power turned on
The clicking you are hearing was probably always there, it's just that when something goes awry, one pays closer attention. What you hear is probably a relay that connects power to the rest of the set. Since our sets can respond to a remote, they always have a little bit of life to supply power to the infra-red receiver so it can respond when 'off.'
I see two possibilities; the relay itself has burned contacts and not always 'closing' as it should, or, the high voltage circuit is failing to turn on as it should causing an excessive current to flow for a moment and a protective circuit to trip and disconnect the power from the main supply.
It probably will get worse if the problem is not found and could damage other circuitry as well.
Good luck finding a TV repair man who isn't deceased or out of business but I do recommend you try to have it repaired. Once repaired, it will outlast most any panel/flat screen-type TV as it appears nearly all of them are failing much too early in life.
You can check by entering just "LCD," "plasma" or "projection" plus TV in the search window here.
Oct 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
I cant do anything with my phone
Could be the screen is not properly attached to the circit board worth while giving it in to a repair shop if your not so good at repairs yourself . Doesnt sound like anything major (hopefuly)
Aug 09, 2009 | Motorola Mobility RAZR V3
My K800i fails to start up after the SE logo. Any help or advice???
Try using Sony Ericssons software update utility to update the firmware or reinstall the existing firmware...
Its available at the Sony Ericsson website, unfortunately the K800 does have quite a few software bugs, white screen of death, black screen, red blinking light, etc...
Please note doing this will delete anything saved on the phone, if you can try using the Mass Storage mode to backup items like images... also if the phone was flash patch unlocked then it will need to be unlocked again
May 13, 2009 | Sony Ericsson K800i Cellular Phone
I have a sony ericsson w950i and it keeps resetting itself
you can do a master reset of it or just get the software reloaded or with the sony ericssons update utility update your phone
http://www.sonyericsson.com/cws/support/softwaredownloads/w950i?lc=en&cc=us
Mar 30, 2009 | Sony Ericsson W950 Cellular Phone
Won't start
im gettin same problem, its a bightmare... it happened when i changed my theme back to normal walkman one. all it displays is the orange screen. i hate this phone now... but i need help. thanks
May 24, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Problems with sony ericson k800i
There is a problem with your firmware. It seems that your software became corrupt. It happens all the time on Sony Ericssons. Bring it to your local cellular service center and they should be abale to flash it for you on the site under warranty. If you run into any problems, look in my profile and i can probably help you out.
Jan 23, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
