Under the bonnet on the radiator is an automatic fan, now if the radiator is low or you need to replace the coolant in it or top it up but the car may need a service and let them know the problem.
SOURCE: clicking, squeaking noise and rough-idle when parked in drive
It almost sounds like you have a heat shield that is loose on your exhaust system. Let it cool, and try to reach under, lightly bumping the exhaust pipes with your hand. If you hear any rattle noises, or squeeks then you have a loose shield. you can ither remove the shield, or try to use a large clamp to go around it and tighten it up.
SOURCE: Engine Knocking Noise
I don't think that the petrol quality will come up with this noise and also the engine is fairly new to have these sort of problems.. Have you run out of oil and used the car? I would suggest a computerised diagnostic if you are getting any error code on the dashboard.It is quite complicated to get an answer for your question...
SOURCE: my 2005 scion xa is making a loud scraping/
SOUND LIKE BRAKE PADS WORN DOWN TO METAL GRINDING ON BRAKE ROTORS.
SOURCE: VSC TRAC AND CHECK ENGINE
did you left your gas cap loosse, well every time check engine lite is on, your vsv lite will come on has well, if check engine lite is not flashing you ok to drive it but have some one scan it asap,j you dont want a problem getting biger,
good luck
