Maytag top loader -- mold smell and mold around rubber ring
  • 3,267 Answers
First check the rubber seals to note if it has become slippery too. If so clean them well so that the slimy layer is gone. Next fill up the machine with water, muratic acid, detergent, I teaspoonful of lemon extract and half a teaspoon of vinegar and a slice old but not dried tamarind pith and run the washer well. After that fill it up with clean water and chlorinate the water upto 10% chlorination and let it run for a while. After that drain and wipe dry. If it can be rolled out under a hot sun, even better.............sodeep
Posted on Jun 18, 2009
  • 15,935 Answers
As with any home appliance, your washing machine requires regular maintenance and upkeep to ensure optimal performance. Washing machines can develop a foul odor after long-term use, and this odor will affect the cleanliness of your laundry. (Please note that the following steps are --> --> maytag top loader -- mold - lg.php?category_id=6&content_type=article&content_type_id=397607&key_page=702171722100359967&site_id=1&bannerid=501&campaignid=37&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f397607%2fhow_to_clean_your_toploading_washing.html&cb=0a8dae4365 window.google_render_ad(); intended for owners of top-loading machines, not front-loaders.)
Step 1 - With your machine empty, run it full of hot water to the largest load setting. When the tub is full and begins to agitate, add 3 to 4 cups of distilled white vinegar to the water. Then add ½ cup of baking soda. Allow the machine to agitate for a few moments, then turn off the machine. Let the water sit for thirty minutes to one hour.
Step 2 - After allowing the vinegar/baking soda mixture to penetrate the grime in the washing machine tub, restart the machine, allowing it to complete the wash cycle. At the end of the wash cycle, as the tub begins to drain, advance the washing machine to the spin cycle. On many washing machines, this will cause the washing machine to spin as it drains, which can help to further loosen any residue. If yours doesn't do this, simply allow it to drain. Turn off the machine.
Step 3 - Wipe the inside of the washing machine tub with a wet cloth. If desired, use a cloth soaked in a solution of half hot water and half white vinegar. Be sure to wipe all inside surfaces, including the bottom and blades of the agitator and the top of the tub just under the lid. (It is sometimes helpful to use a wire toilet brush around the top rim and in hard-to-reach places.) If the washing machine has a fabric softener and/or a bleach dispenser, remove these and clean thoroughly before replacing.
If after following these steps the odor remains, the washing machine may have build-up in some of the inner parts. If your washing machine is still under warranty, contact the manufacturer for a repair person to check it out. If not, contact your local appliance repair shop, and they should be able to clean the machine for you.
If the mold has already permeated the rubber - change it, as it will continue to re-appear. Also - leave the lid open when not in use to minimize moisture.
Thanks for using FixYa!!
Posted on Jun 03, 2009
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
I get a very strong smell from my maytag atlantis washer. it smells like the sewer. how do i remove that smell?
Confirm that the sewer trap is working. The sewer trap for a washer is the pipe connection where the washer drain hose connects.
It would not be likely that the trap is a problem. Sewer gas and mold can smell similar. Smell around the hose connection. Some older homes just simply had a drain to the outside
26162560-vtficdakbbyhbpkipaftpy0h-4-0.png Next this machine is a top loader and if it is being used several times a week the problem is likely around the tub on top. Mold will form in the tub under the basket if it is not run weekly. Normal wash cycle in a top loader should keep under the basket clear. If a week or so occurs between use then the problem can be under the basket at the bottom of the tub. Use bleach, vinegar, or baking soda in moderation to clear.
It is more likely that the problem is around the top of the top. this requires opening the top and swinging it back to get access. Make sure power is removed before attempting.
Cleaning a little bleach, soap and water.
26162560-vtficdakbbyhbpkipaftpy0h-4-9.jpg this helps?
Apr 13, 2016 | Maytag Washing Machines
The washer bucket has developed a black mold & smells.can I fix?
first you have to wash the mold away the next solution is to go to home depot and pick up a product called affresh it cleans out the inside of your washer this is a once every 1-3 months product that will also prolong the life of your washer and all front loaders ive also found that this works great in top loaders as well
Apr 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
Smell of mold and mold on rubber in front loader
If you don't leave the door open when not in use and not wipe the door dry and the door gasket dry, mold will build up as there is no air to let the moisture escape into. Makes sense, manufactures do no not say this in their manuals, I think they should !
Mar 20, 2010 | Maytag Neptune MAH6500A Front Load Washer
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water sitting and mold growing in the rubber gasket ring around the opening for the door
affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 09, 2009 | LG WM-2277HW Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
Aug 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
Jul 24, 2008 | Maytag Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
