Question about Toshiba e-STUDIO 50F Plain Paper Laser Fax
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
E-studio 50 f error code 021 how do I resolve this?
I am a trained Toshiba service engineer, I use the service mannuals nad the service handbook given to me during trainning to solved the problem thanks.
Posted on Jun 05, 2009
    President:
  • 3,085 Answers
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Posted on Jun 04, 2009
  • bong_cuan191
    bong_cuan191 Dec 11, 2012
    done that 6 times but still err 021 please help thanks
    New Friend:
Please I have a brand SHARP AR 2820 Machine I wanted to make copies of my book but present myself on the screen H4 what I can do to remove this error if you help make sure
Posted on Sep 30, 2016
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
MY TOSHIBA E-STUDIO 452 HAS A MESSAGE OF INSTALL NEW TONER AND I HAVE INSTALL A NEW TONER ALREADY
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
May 18, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba 50 f showing printer error 21
toshiba 50f printer err 021 solve it my problam
Jun 01, 2011 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Machine on there is no error code but not going to be ready.(tosiba studio 282
have you replaced the toner cartridge?
If the machine sounds like it is "cycling" then the toner may have run out and for some reason the toner light has not come on.
Oct 20, 2009 | Toshiba e-STUDIO 282 Black and White...
Error code 021
Press
Function
7
6
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
Feb 13, 2008 | Office Equipment & Supplies
Printer error Info code=021
Hi, machine error/info codes usually require service. Attempting the following involves some risk, you may loose complete access to your unit or not do anything at all. It is strongly recommended that you call a qualified service personnel/professional. However, if you feel like giving it a try while praying..... reset the system: Power on, wait for a minute or two, Function button, 7 (keypad), Monitor button (4X), soon as you hear the beep punch * (keypad). You will now be in the service menu. If no service menu, stop, do not power off, unplug. If in service menu, 7 (keypad), Set, go to Reset Option (arrow down one step), Set. Unit will prompt you to reset, press 1 for yes, system will confirm that it has completed resetting. Go back to main menu (Stop button), power down, wait again for a minute or two, power up. Please remember that resetting may, can and will erase all your personal settings and preferences including day/date/time, etc. The above steps may make your unit completely useless. If still you have the 021 code, you can brute force it to reset. Power on without a toner cartridge. In self-test, it will check itself and reset many functions to determine faults (including toner cartridge and your code 021). Wait again for a minute or two, Power off, reinseert the toner cartridge, wait again for a minute or two, and power up. If all else fails (including the prayer) pls go back to the first paragraph. The above steps are not mine but were described by a good samaritan. Hope this works out for you and lots of luck.
Apr 24, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
Toshiba e-STUDIO 50F Plain Paper Laser Fax Logo
495 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
