Question about Panasonic Audio Players & Recorders
Error 61 and does not operate
I have a panasonic ak500 and shows error f61 It does not work
  • 6,784 Answers
Error F61 represents a failed main board(motherboard). this can happen during a surge or, it can be just age related or heat. the microchips are laced with a thermal compound and, this compound will thin over time. i would also inspect the optical lens assembly as well. This model is programmed to show this code if the lens is damaged as well. In most cases, it will be the main board.
Posted on Jun 03, 2009
This F-61 error is a hell of a problem i've tryed replaceing the fan wit a new one,, didn't work then i put the old fan back and it works but still nothing but this f-61 (I unpluged everything in...
Have you tried it with no speakers attached? Was it overheating? If not, why replace the fan?
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 22, 2011 | Panasonic SC-AK500 CD Shelf System
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
F61 on screen
Check out the cold weldings in the circuits, It worked for me
Aug 26, 2009 | Panasonic SC-AK500 CD Shelf System
F61 appears on my setero when i push play
my dear friend. this error message means something is broke on the audio power.
the unit give that message when the chipset find fix current or signal on any audio channel.
the most common means you have to change the audio amplifier unit. sorry but i know is the true.
Jun 15, 2009 | Panasonic SC-HT830V System
F 61 Code
The if the "bad sound" is coming from the speaker(s) it probably needs the output ic. If it is coming from the player itself check that the fans are working. F61 is an amp error code but a non-rotating or unplugged fan will also set it off.
Feb 09, 2009 | Panasonic SC-HT920 System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
F61 Error Code Panasonic SA-AK500 Audio w/ CD Exchange
The output IC may be defective. Part number RSN35H2-P.
Feb 07, 2008 | Panasonic SC-AK500 CD Shelf System
720 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
