Question about Panasonic Lumix DMC-FS5 Digital Camera
Memory card error
I put a new memory card in my camera and it won't work. The LCd screen shows Momory card error
  • lridgley Jun 03, 2009
    I lost the first card that I had for the camera. THe camera won't even let me format the card and the camera does not work withteh card that we keep in our other camera. I am goign to try and buy the sandisk 1gb card and see if that works, and try and format on my computer the other card I just bought with my card reader...hopefully that well work.....I did get the error every once in a while before withthe old cared but I could turn the caera off and back on and the problem would solve itself
    Scholar:
  • 145 Answers
Problem is most likely caused by uncompatible sd card size.
Posted on Jun 03, 2009
  • Panasonic Master
  • 13,433 Answers
The memory card most likely need to be formatted, There should be a option for that in the camera somewhere, in the setup most likely. It should be "format" use it to format the card, if that doesn't help, do you have a card reader?
we could plug the card to the computer and format it there.
to format the card on your computer plug it in, if it has a problem the format message should come right up, but if it doesn't open my computer from either desktop or from start -> my computer.
find the memory card from the list, you could disconnect the reader, press f5 on the my computer window, plug it back in and press f5 again to see what disppeared and reappeared, thats most likely it, or one of them is the right one, ones you have found the right one or a suspect(should read Removeable storage device) right click on it and select format,
click on device defaults we can try the format atleast 2 times, both times with diffrent setting. Try FAT setting click on format and let it run, ones its done, disconnect the card and plug it to your camera and see if it works, if not, plug it back into the computer and this time try FAT32 setting instead of FAT. Ones its done connect it back to the camera and see if it works.
By the way do you have other cards that work perfectly with the camera?
Let me know how that goes,
Thanks,
Ekse
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Well i am going on a trip tomorrow and i put my memory card into the lap top and put all pix on the lap top and then put it back in to the Nikon and i gray screen came up and said that "momory card is writ...
Some memory cards have a small plastic tab on the side of it that can be set to write protect the card. Check your card to make sure the tab didn't get moved accidentally.
Jul 01, 2010 | Nikon Coolpix 4500 Digital Camera
Why does it say memory card error on the screen
Hi there, For few reason camera showing memory card error.
1. Memory card damaged.
2. your memory card finished is life time storage memory.
3 . virus infected.
4. If your memory card storage capacity more than camera support card then its also show to you. For example your camera support maximum 2 GB card, but your try to use more than 2 GB memory card.
I suggest your remove the memory card and scan by updated antivirus. After that, if not working then fomat it and try.
Thanks & waiting for your feedback.
Feb 15, 2010 | Canon PowerShot SX 200 IS Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Card error -Revolt 500 Olympus
i have the same problem out of no wheres the lcd screens says card error ive been formatting allmy cards for the past 2 days & no luck whatso ever! its brutal im lost with out my camera any solutions???
ive even tried new cards that werent used before!
Feb 24, 2008 | Olympus EVOLT E-500 Digital Camera
Error #45
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
Jan 04, 2008 | Kodak EasyShare Z740 Digital Camera
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
515 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
