Question about Toshiba 55H70 55" Rear Projection Television
Ics upgrade what ics can I upgrade to from 392-110 without changing anything else???
  • tmitchell508 Jun 03, 2009
    I`m down for the wrong tv--I have a hitachi51swx20b if that matters...
  • Toshiba Master
  • 5,138 Answers
Up Grade to the 392-180s they are the Best! hold up Rating is 100%.
Posted on Jun 03, 2009
  • ladywinn
    ladywinn Jun 05, 2009
    If your STKs are 110s upgrade to the 180s,also replace 7 resistors in same circuit i will have to look them up in my mannel,will post them asap.
Reboot after 10 seconds.
You have accomplished what is known as "bricking" your device. If anything interrupts a firmware update, in most cases the equipment will be unable to recover from it. It will require factory servicing to reestablish the firmware. It is usually cheaper to buy a new device. Remember this about firmware upgrades - just because one is available does not mean you should upgrade. Many devices will work forever without them. Unless you are in a situation where changing requirements of your equipment and/or providers means an upgrade MUST be performed, the best rule is "if it isn't broken, don't fix it!"
May 17, 2016 | Computers & Internet
Can I update Huawei U8661 to ICS?
I want to upgrade HUAWEI U8661(version 2.3.6)to ICS version,so help me.
Dec 24, 2012 | Huawei Sonic Plus U8661 Dual Sim 2 Line...
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 08, 2011 | Computers & Internet
I have red convergance problem.. This is the second time I have replaced all diodes and the stk chips. they dont have any 110 stk chips so i am using 150 stk chips. I replaced all diods and now RK 62...
Alot of techs recommend using the higher wattage ICs to replace the stock ones, which is never a good idea since the resistors get stressed. Upgrading to the STK394-160 IC is the only upgrade Hitachi recommends but then the values of the resistors need to be changed since the stock resistors will not work with the upgraded ICs
Oct 09, 2010 | Hitachi 61HDX98B 61" Rear Projection...
Need to find a convergence kit for a pt47wx53g projection tv
Mats Electronics has the STK ICs you need .
1-800-628-1118
STKs will have part number on them ,example STK392-110 go by number printed on them if they are 110s upgrade to 180s Better ICs.Let me know if their is anything else that you may need help with.
Mar 25, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Replaced IC chips, but can't fine-tune convergence.
U know how to use a multimeter right?Check and replaced all the resistors near the 2 convergence ICS.Most resistors are big and blue core in colors.
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
Smoking Replacement IC'S!
You used the wrong ICs STK392-110s upgrade to 392-180s.
Nov 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence repair problems.
alot of people make the mistake of putting two STK392-150 Ics in the Hitachi , and most times it will not work unless you change all the convergence resistors.. If youre going to upgrade hitachi to anything other than the stock ICs, it is recomended by Hitachi to use the STK394-160 ICs but then you have to change the ratings on the resistors. You can get the upgrade kit for your hitachi at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Replacement convergence chips
I you give me your complete STK number such as STK392-010 as an example I can tell you what you can upgrade to also it does not require any resistor change when you upgrade but send me your complete IC number that you have and I can tell you what to upgrade to thank you
Apr 26, 2008 | Samsung HCM5525W 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
