Question about Ricoh Office Equipment & Supplies
How to reset a Ricoh 411dn printer to initial settings
I need to find out how to reset a Ricoh 411dn printer to factory settings.
  • Mike Dotson May 11, 2010
    What is wrong with the printer that you would want to do that? You can go into the menu on the control panel and change settings, setting to factory default might cause more problems.
5 Suggested Answers
SOURCE: ricoh aficio 1035 factory rest now unable to get into settings
Press. and # both simultaneously by but of 10 seconds until it is extinguished, this restores the values of factory, with luck this had to solve it.
Posted on Dec 07, 2009
newport74
  • 58 Answers
SOURCE: how to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Posted on Feb 27, 2010
  • 57 Answers
SOURCE: Ricoh MP 4000 reset to
You can reset admin password when you open sp mode with login supervisor (no password)
Posted on Jul 05, 2011
  • 94 Answers
SOURCE: factory reset
this question is best answered by the epson site
http://www.epson.com/
Posted on Aug 16, 2013
Printer does not reset
NVRAM initialization/cold reset
NVRAM initializer sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initializer resets the following:
! all menu settings to factory default values
! factory settings such as formatter number, page counts, factory
paper settings
To perform NVRAM initialization
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
4 Release the GO button.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Or download the service manual here ..
http://www.google.com.sa/search?site=webhp&source=hp&q=hp+laserjet+1200+printer+service+manual&oq=+HP+LaserJet+1200+Printer+service+&gs_l=hp.1.0.0j0i22i30l6.200423.206442.0.207913.10.10.0.0.0.0.763.3187.0j3j2j3j1j0j1.10.0...0.0...1c.1j2.9.hp.QNDAx6nGCA0
Apr 18, 2013 | HP LaserJet 1200 Printer
Reset memory for ricoh sp5100
Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list.
Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
Feb 08, 2013 | Ricoh Office Equipment & Supplies
RICOH AP610n Factory Reset
press the counter key and then press and hold the # key and tap on system settings on the screen . it will ask if you want to reset the machine to factory mode, select yes and wait for the machine to reboot.
thanks and all the best.\
for further clarification, call +233243494871
Mar 12, 2012 | Ricoh Aficio AP610N Laser Printer
May ricoh 1045 bao loi SC 329,mong cac chuyen gia giup do
this is laser unit code.press reset 107 hold the c key. press copy sp go in drum perform2109 400dpi initial setting and 600 dpi initial setting.
Aug 07, 2011 | Ricoh Aficio 1035 Copier
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh aficio 1035 factory rest now unable to get into settings
Press the SNC raport and change /set the value default.
Dec 02, 2009 | Ricoh Aficio 1035 Copier
How to restore to factory default settings ricoh
5801 Memory Clear
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
How to reboot the ricoh aficio 1515mf. i could not use as all were password protected. how to erase all the password and memory??
To clear the memory (reboot) the RICOH AFICIO you will have to send it to the factory where they will wipe the memory and restore the machine to its defaults.
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
