Question about EliteGroup K7SOM Motherboard
Case front panel to motherboard wiring
I unhooked the power switch, reset switch, power led's, hdd led wires as well as the data1, vcc1, grd1, data2, vcc2, grd2 wires on the elitegroup k7som+ v:7.5c motherboard and can't remember where they go! Can someone send me a diagram or help me with this problem?
    President:
  • 2,559 Answers
Here is a link to the motherboard manual
And here is the hook up
Posted on Jun 03, 2009
  • 326 Answers
Look on your motherboard youll find an area that has 2 lines of pins with about 6-8 pins on each line (diferent motherboards vary)
you will see next to the pin the corosponding text on the motherboard (HDD etc) to the end connections on your cables. you might not find your block connector in the same place but you get the idea.
let me know if you still cant find it, if you can give me your motherboard model number i can find a manual for you
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
How to connect panel 1 of n68s3+
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Pins 1, 3, 5, 7, and 9.
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
HarDDrive activity LED.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
How to re-wire a Compaq Presario SR2150NX Case power Switch
The plastic front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
F_PANEL_1
The Front Panel header contains connections for the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864922&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339274
(Look at the motherboard photo. The Front Panel header is at the bottom right. Scroll down for the motherboard illustration )
There are 9 contact pins.
4 across the Top row, and 5 across the Bottom row.
The four pins across the Top row are numbered EVEN.
From the Left side going towards the Right side;
Pins 2, 4, 6, and 8. There is NO pin 10, just a blank spot.
The five pins across the Bottom row are numbered ODD.
A) Pins 2 and 4 are for the Power On switch
B) Pins 6 and 8 are for the Power On LED
(LED is dim when the computer is on? Switch the wires around )
C) Pins 1 and 3 are for the HarDDrive activity LED
(LED is dim when the harddrive is operating? Switch the wires around)
D) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
How to know which wires are for the Power On switch, Power On LED, and HDD LED?
Follow the wires into the Front Panel. Remove the Front Panel, and follow them.
(Need guidance removing the Front Panel post in a Comment )
Regards,
joecoolvette
May 02, 2012 | HP Compaq Presario SR2150NX PC Desktop
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Front panel hookups
go to the link below and you can download the manual for instructions on front panel connections http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Manual&DetailDesc=GeForce6100SM-M(V1.0)&CategoryID=1&MenuID=39&LanID=9
Sep 01, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
EliteGroup K7SOM Motherboard Logo
5,926 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
