Question about Dell 926 All-In-One InkJet Printer
Where is the ink cartidge compartment??
Where is the ink cartidge compartment on the Dell 926 printer? My circumstance is somewhat similar in that I need to change out both the black and color ink cartridges. My cartridges have arrived from Dell but I cannot get the cartridge holder to return to middle when I open the lid. I have restarted computer and printer and rebooted printer, but nothing works. What am I forgetting to do? How do I troubleshoot this issue?
    President:
  • 2,559 Answers
Just raise the top lid and the cartridges will come to the center and stop
Posted on Jun 03, 2009
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
I was given a new Lexmark X2690. Before I have someone ready it for my use what do I need to purchase besides black ink. Do I need a cable, bcg plug? or whatever it is called - anything else? Are the...
Welcome to FixYa.
The complete setup material for your printer are as follows:
1. Lexmark Black Ink Cartridge #4A
2. Lexmark Color Ink Cartridge #5A
3. Power Adapter (looks somewhat like the picture below)
4. USB Printer Cable. Please refer to the image below and see if you can interchange it with your DELL Printer 926.
5. Printer CD Software (Drivers) to be installed in your computer.
I hope that this will help.
Thank you for using FixYa.
Jas247
Mar 07, 2011 | Lexmark X2690 All-In-One InkJet Printer
DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
Follow the below instructions
  1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
  2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
  3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
  4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
  5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
  6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
  7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
I hope this clears up your problem.
Good Luck and Have a Nice Day!!
Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
Cartridge alignment problem - it says to remove tape from cartridge or troubleshooting. There is no tape on the cartidges.... HELP!
Are you using Dell Series 9 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
Do you have a '926' or a '962' printer? You've cited each number in your problem description.
Remove the ink cartridge.
Reinsert the ink cartridge.
If the problem persists, contact Dell, and get them to replace it.
Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
http://support.dell.com/support/edocs/systems/prn926/en%5Cindex.htm
click English and download this zipped file. in the search area of the page that opens when you unzip you will see "ink replacement" there are nine steps there and lots of pictures...it is pretty easy. I would run the process after install the cartridges.
Hope this does the trick for you,
Please leave rating, thank you..
May 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 ink cartridges holsters won't show up
Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
May 03, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 Printer ink refill instructions
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
108 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
