Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Small production of ice? What should be the normal production of ice?
The km 450 mab is producing a small amount of ice. What is the amount it should be producing? Kathy
    Problem Solver:
  • 16 Answers
A KM-450 MAB at 70 air and 50 water will produce approx. 460 lbs. cycle weight should be 10.4 lbs. per batch this is of course in perfect cond. time to make is 30 min. freeze and 4 min . Harvest. To give you the worst case scenario 100 air 90 water you drop to 340 lbs. cycle weight is the same but time to make is 32 min. 3.5 harvest. If you have more ?s I have included the link to the Manual for this unit.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Posted on Jun 23, 2009
  • Hoshizaki Master
  • 1,250 Answers
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Posted on Jun 05, 2009
Why would a hoshikia 450 mab jump from freeze cycle to harvest cycle without giving iot enough time to makle aload. would it be the cube sizer adjustment or a bad borard?
clean and dry the sensor and restart the machine. Adjust the thickness until the cubes make a plate but break apart when they fall in the storage bin
Jun 01, 2014 | Hoshizaki Freezer Commercial Ice Machines...
WHAT IS THE CAPACITY OF MODEL F-450BAE FLAKER
It is to produce 450 pounds of ice in 24 hours under ideal conditions. Manual says anywhere from 345 to 440 depending on factors of water temp., ambient temp., and system pressures.
Hope this is what you are looking for.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have a hoshizaki km-250bwf and it the comprsser
Check the control board for a "output" test switch.
If it is "ON",turn it off.
Nov 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Not producing ice like it should
Just what does this mean? Does it seem to have a lower production? Let me know and I'll give you a hand in correcting.
Aug 11, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine with constant beeping every 2 seconds
turn it off and on and check the drain line and see if its draining water. some times the check valve needs taken apart and cleaned. the problems corespond to water related problems. usually because its taking too long to freeze. good luck
Dec 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
KM 280MAH
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Sep 04, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
335 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
