JVC HD52G887 52" Television Logo
A
Anonymous Posted on Jan 26, 2014
I am stuck on antenna signal mode, i have no remote, my tv will not get off of antenna signal strength test
Need help
Tv is stuck on anntena with only 1 channel I am trying to hook up cable tv. I do not have the remote anymore. When I program channels it only finds channel 1
In settings, find INPUT or SOURCE, select CABLE and go from there. To find channels on when using the ANTENNA mode, you have to have a DIGITAL antenna hooked up to the TV. It will then search for any stronger digital signal. Most of the time if you move the antenna after the signal search, you will have to do another search to receive the signal.
2answers
Television weak signal how do I fix it?
There are a number of things you can do to improve the quality of the signal getting to your television.
Firstly review your aerial to make sure it is high enough and pointing in roughly the same direction as all the aerials for your neighbours or other buildings around.
If you are using an indoor aerial or portable you will need to move it round the vicinity until you get the best signal. This is mostly trial and error.
Once the aerial is in a good position you need to connect it to your television. The shorter the cable, the less signal loss, and the better the signal reaching your television. You can also use a better quality cable - think thicker with higher shielding - and this will also improve the strength of signal reaching your television.
If your problem is something different leave another message and I'll see what other help I can give.
4answers
My signal strength is really bad on my TVs. Should I buy a new antenna?
The more tvs you have hooked up to the same antenna, the lower the signal strength. Therefore you should get an antenna amplifier or get a new antenna with a stronger signal.
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
4helpful
2answers
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
2helpful
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
No antenna siganl strength
Antenna may not be compatible with DTV signals or not aimed correctly.  Go the www.dtvanswers.com and click on the Antennas tab at the top for more info.
Digital built in turner
You'll need a better antenna. All the TV can do is show you the signal strength at the antenna input. If it's too low, only changing the antenna can help. This could mean simply adjusting the antenna position. You might need to replace the antenna with something larger or with a built-in amplifier. In severe cases, you might need to install an outdoor antenna to get a useable signal. With digital broadcasting it's all-or-nothing. A weak signal will either go undetected by the tuner or cause a blocky freezing (pixellated) display.
Tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
