Question about Philips CDR600 CD Recorder
Philips 765 CDR - twin deck
This machine has\always been reliable, but recent problem with CDR side going into 'recover', during deck-to-deck recording.
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Posted on Dec 25, 2010
Power failed in middle of a recording session when the machine was in Pause mode. How can I recover the recorded file?
You can try computer software like Nero or Roxio and finalize the disc as it is. This is exactly why I had advised Churches that went from reliable cassette tapes to CDR to put UPS units on the CD recorders as they do not react too well to power outages. If you were using an Open Reel there would be very little loss of the recorded signal.
Mar 24, 2013 | Marantz CDR-300 CD Recorder
NECESITO EL PLANO O DIAGRAMA ELECTRONICO DE EL EQUIPO -PHILIPS AUDIO COMPACT DISC RECORDER CDR 765. DESDE YA, LES AGRADEZCO SU ATENCION CARLOS CISNEROS
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
Jun 17, 2011 | Philips CDR765 2-Disc CD Recorder
Phillips cdr 200 recorder, just recorded 13 tracks with time left over on sony brand recordable cds for music. i switched from analog to digital to finalize and it took 4 mins however RECORDABLE still...
It sounds like it didn't truly finalize. Try finalizing it again since the 'recordable' status implies it still qualifies. You have to press RECORD immediately after FINALIZE.
The Philips directory lists a few CDR200 models but the documentation contains directiosn for CDR765.
http://www.p4c.philips.com/files/c/
for example...
http://www.p4c.philips.com/files/c/cdr200bk/cdr200bk_dfu_aen.pdf
If for some reason you ever want or need to extract music from a non-finalized CDR or CDR-W, try loading it into a standard DVD player. Without a TOC the player won't be able to display track info or navigate to individual tracks but it MAY play it straight through anyway and you could digitally capture all or part of the output on another CDR. Just be aware that if the original is rewriteable and has old data beyond the new data you will crash into it without warning at the end of the new data, so be ready to pause your copy at the appropriate time.
Apr 07, 2011 | Philips Audio Players & Recorders
How do I get a user manual for phillips cdr 765 recorder?
You can download the manual from the manufacturer's web site at
http://download.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_aen.pdf
Apr 02, 2011 | Philips Audio Players & Recorders
Can i connect my mixer to the input of the cdr 765 then connect the amp to the outputs. Will this work and record?
If you just treat the CDR as a tape deck, I'm pretty sure your mixer has accomodations for that. Then you won't have to connect the amp to the CDR and anything you want to mix/monitor will be available to the amp.
Jan 11, 2011 | Philips CDR765 2-Disc CD Recorder
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
I have a philips music system , model no is fw326/12. now porblem is, in tuner mode i celect fm band the frq.108 is not aper.
I HAVE A CDR-765 PHILIPS AUDIO RECORDER AND HAVE PROBLEMS ABOUT FINDING THE RIGHT CD . BECAUSE AT THE MARKET IN ISTANBUL THEY DON'T SELL ANYMORE CD-R Q PHILIPS AUDIO BLANK CD S . INSTEAD OF THESE WHICH CD DO YOU RECOMMEND . BY THE WAY I AM PRODUCER AND NEED URGENTLY YOUR HELP .
BEST REGARDS
NINO VARON
Jan 19, 2010 | Philips Audio Players & Recorders
Philips cdr 765
I just purchased one from Ebay. It plays fine on both sides. The recorder will recognize CDR's and the display will say recordable media. But, when I attempt to actually record, it won't work. I have another unit exactly like this one and the CD's I have work fine with that unit. I'm guessing this unit's recorder is bad? Any suggestions? Thanks.
Nov 06, 2006 | Philips CDR765 2-Disc CD Recorder
Open Questions:
Philips CDR600 CD Recorder Logo
298 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
