Question about Pioneer Car Audio & Video
Connection radio car
I need electric scheme to conect radio car type KEH-2400SDK
    Scholar:
  • 84 Answers
GO TO WALMART. SPEND THE 10 DOLLARS ON AN AFTERMARKET HARNESS NO THINKING INVOLVED.
Posted on Jun 14, 2009
I need an unlock code for my pioneer KEH-P4900 radio cassette player. Can anyone help?
pioneer does not have security codes. what is the problem with the radio.
Feb 06, 2011 | Pioneer KEH-P4900 Cassette Receiver
I need to connect the battery on my car, does the pioneer keh-p6020r have a built in security code?
If you are not sure, then try this
If you do not have the code (and you have NOT replaced your battery yet ) then you can protect your radio memory by either connecting your battery charger across the cables when you remove them from your battery OR buy one of these off Ebay (or make your own using a PP9 and a Cigar Lighter Lead.)
Ebay Search : CAR MEMORY SAVER
May 17, 2010 | Pioneer KEH-P6020R
How and where to connect an AUX source (e.g. MP3 player)?
Cassete players do not have Aux Inputs.
You will need to use an FM Modulator type Aux device that will broadcast to a radio station preset on your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Pioneer KEH-P6600 Cassette Player
How do you install a jvc cd player in a 95 carolla is the colors the same
Most new radios have a diagram or wiring scheme that tells you which wire goes where. Usually there are 2 power wires(one goes to ignition wire and the other to the battery B+ wire). Then there are the Power antenna and Ground wires. Once you have these in place you can figure out the speaker wires. #1 You need a DMM (Digital Multimeter), wirecutters, wirenuts, lineman pliers and electric tape. #2 There are only 2 wires that should put out a voltage. So set your DMM to DC voltage at 20 voltage range. (If your battery is 24V set your DMM to next highest range.) Connect the black test lead of your DMM to ground(usually a black wire). Connect your red test lead of your DMM to all of the dash wires ONE AT A TIME until you find ONE that puts out a voltage of approx. 12 V. That is your Battery B+ wire. Mark it and set it aside. Now to find the ignition wire. Note that your ignition wire will not put out a voltage until you turn the ignition ON. So turn ignition ON and find it by connecting blacl test lead of DMM to ground wire and the red test lead of DMM to each of the remaining wires until you read 12 V. Be sure to double check by reading both wires while ignition ON and OFF. Mark the Ignition wire and set aside. #3 Now that the wires that put out a voltage are out of the way, set your DMM to Continuity Tester. This test is done with power off(no more power emitting wires anymore remember). This test checks for continuity or a path which current can flow through. It does so by 'BEEPING' when the leads are connected to both ends of a connecting wire. So start checking the wires by connecting black lead to one wire and red to another wire. Mismatch until you find two that will make a beep. That pair of wires connect to a speaker. Band the pair together and find 3 more pairs. Those four pairs are the wires to the four speakers in your car. #4 You can now make the proper connections using the wiring scheme on the radio. So far you can connect the ignition wire and the battery wire. Theoretically if you were to turn on the ignition power is going into the radio but the negative/ground needs to be connected for the power to flow. Other than the other 8 speakers wires there should only be 2 wires remaining coming out of the dash. One would be the ground and the other the power antenna. With the ignition on and the radio turned on tap the power antenna wire from the radio to one of the 2 remaining wires. Taping the ground would not power the antenna but taping the power antenna wire will. So find out which is the power antenna by quickly tapping it. Most ppl would not recommend this type of testing. Make proper connections once finding which is which. #5 At this point the wiring scheme on the radio tells which pair of speaker wires is for which of the four speakers in the car. 1) rear right; 2) rear left; 3) front right; and 4) front left. With the ignition on and the car radio on take any pair from the radio and soft connect to a pair on the car. One of the speakers will play. Note which one and find its coresponding connection on the wiring scheme. Do two more in the same manner which would only left one on the car and one pair on the radio. #6 Remember to make good connections using the linemans pliers to twist the wires tightly together. Plus secure all connections with wire nuts and to be safe also secure with the electric tape. Try to keep wires neat and secure. I hope this helps. =)
Oct 10, 2009 | Car Audio & Video
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
Pioneer KEH-P4830R connection to AUX source
Hi. Sorry, I can't actually solve this one for you but was hoping you may be able to look in the manual and let me know which model number CD changers are compatible with this headunit. We don't have the manual and so far have been unable to find the answer anywhere so your help would be much appreciated.
Thanks
Lee
Jan 17, 2009 | Pioneer KEH-P4020 Cassette Player
I have pioneer KEH P2030 radio/caseete. How do i save radio stn
Usually, you can tune it to the station you want, push and hold down the numbered buttons
Jan 16, 2009 | Pioneer KEH-P2030 Cassette Player
Hi, I need a wiring diagram for a Pioneer KEH-P3630R Radio/Cassette system
s.gif Faisceau avec connecteurs ISO pour autoradio PIONEER 12 broches
NEUF SOUS BLISTER
16 broches sur ISO - Dimensions de la prise environ 43 x 8 mm
Détail des câbles des haut-parleurs :
Blanc : HP avant gauche +
Blanc/noir : HP avant gauche –
Gris : HP avant droit +
Gris/noir : HP avant droit –
Vert : HP arrière gauche +
Vert/noir : HP arrière gauche –
Violet : HP arrière droit +
Violet/noir : HP arrière droit -
Détail des câbles d'alimentation :
Jaune : Permanent + 12 V batterie
Rouge : Alimentation + 12 V après contact
Noir : Masse
Bleu : Antenne motorisée
cote_g_olitec_j.gif Liste des autoradios compatibles :
cote_g_olitec_j.gif Série KEH cote_d_olitec_j.gifKEH-1100SDK
KEH-1150SDK
KEH-1200SDK
KEH-1300K
KEH-1300R
KEH-1300SDK
KEH-1311
KEH-1400R
KEH-1400SDK
KEH-1450
KEH-1450R
KEH-1500
KEH-1500R
KEH-1530
KEH-1530R
KEH-1540
KEH-1700
KEH-1700R
KEH-1730
KEH-1730R
KEH-1800R
KEH-1830R
KEH-1900R
KEH-1930R
KEH-2100R
KEH-2300R
KEH-2400R
KEH-2500
KEH-2500R
KEH-2520R
KEH-2530R
KEH-2700R
KEH-2710R
KEH-2720R
KEH-2730R
KEH-3400
KEH-3520R
KEH-3700R
KEH-3710R
KEH-3720R
KEH-3730R
KEH-4400R
KEH-4500R
KEH-4530R
KEH-4700R
KEH-4730R
KEH-5700R
KEH-5730R
cote_g_olitec_j.gif Série KEH-P
cote_d_olitec_j.gifKEH-P26R
KEH-P27R
KEH-P28R
KEH-P2800 R
KEH-P2830R
KEH-P3300 R
KEH-P3400 R
KEH-P3600 R
KEH-P3630R
KEH-P3700R
KEH-P3730R
KEH-P4300R
KEH-P4400R
KEH-P4500R
KEH-P 4510
KEH-P4530R
KEH-P4600R
KEH-P4610R
KEH-P4630
KEH-P4630R
KEH-P4700R
KEH-P4730R
KEH-P5700R
KEH-P5730R
Jul 14, 2008 | Audio Players & Recorders
Car Audio & Video Logo
96 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
