Question about Dell Inspiron 600M Notebook
Dell 600m won't power from ac
I have a dell 600m That last night would start to boot then quit. I traced the problem to it was trying to boot only from the battery which is low. It is not getting ac power. I metered the cord 19.5 vdc. I also tryed removing the battery and still nothing. Any ideas
    Scholar:
  • 84 Answers
It could be the charging port is loose or has gone bad outrightly. If it is shaky or has a dry joint, then try scrapping off the solder and resoldering ok. Power down the pc and then to AC supply to see whether it charges. If it does, then you probably have a corrupt operating system and should be re-installed. If the RAM becomes unstable, it could also come with such a problem. Hence, I suggest too that a confirmed working and compatible memory should be tried on your pc. If all failed then your motherboard is bad and should be replaced. Good luck
Posted on Jun 03, 2009
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Won't power up. Battery is charging though.. Help! How hard is it to replace the power supply in a Dell laptop?
There shouldn't be any wait time once you plug the laptop in you should be able to boot the machine. Reliable ac adaptors are found at many good tech places of course to be 100% certain could shop from Dell.com
Jan 16, 2010 | Dell Inspiron 600M Notebook
The Dell Inspiron 600m will not power up when you press the start button. Battery is fully charged. BLY
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
If there is still no display, tell me if there is also any lights that flashes on the (numlock, scrolllock, capslock). Hope this helps
Dec 15, 2009 | Dell InspironTM 600m Notebook
I have a Dell 600m that boots up and then screen
try turning the computer off for 20 min.or 40 min. then turn it back on
Jun 16, 2009 | Dell InspironTM 600m Notebook
CAN NOT CHARGE BATTERY AND AC POWER NOT WORKING ON MY DELL 600M INSPIRON
the battery could be a bad one or it my be a bad dc jack and would need to be replaced
Apr 28, 2009 | Dell Inspiron™ 600M PC Notebook
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
The Caps Lock Flashing then going off is a power on self-test code. Here is the Dell troubleshooting guide to the issue.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=084A4C3E0A9C9EEEE0401E0A55172321&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
From my experience, if removing al customer removable devices failes to make the system post properly, the motherboard will need to be replaced
Nov 24, 2008 | Dell Latitude D600 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
No power
Two things you can do. 1- remove the battery and try starting with the supply only. Dell batteries are notorious for causing a no start. 2- remove the memory and try starting with one chip in one then the other slot, then try the other chip. A bad memory chip can also cause a no start. If these don't correct the problem, then it's going to be with a motherboard component, most likely the power management system. You will need to take it in for a professional diagnostics in order to trace the exact problem area.
Aug 04, 2008 | Dell Inspiron 600M Notebook
Dell Inspiron 600M Notebook Logo
126 people viewed this question
Alun Cox
