Question about HP DeskJet 5150 InkJet Printer
HP5150 print cartridge light flashing
Message indicates incompatible cartridge but I amusing the correct cartridge and even tried a new one, still dead in the water. help please!
    Scholar:
  • 84 Answers
You should try confirmed working cartridges on your printer or use yours on another compatible printer around you before you can be sure. A new cartridge could come with factory fault you know. The other thing that can a suspect in this circumstance is the Carriage where the cartridges are installed. A defective or bad carriage will show up as a cartridge error. Be sure of these devices and the solution is around the corner. Good luck
Posted on Jun 03, 2009
2 SEPARATE FLASHING LIGHT INDICATORS FLASHING. I HAVE ABSOLUTELY NO PAPER JAM.
"All lights blinking and printer not responding" is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 15, 2011 | Office Equipment & Supplies
Power light keeps flashing and the printer does nothing else. No printing, communitcating with PC.
Mar 15, 2011 | HP Deskjet 3915 InkJet Printer
I replaced one ink cartidge magenta and it appears to be ok, but it will not allow me to cancel flashing cancel button and it will not print
disconnect the power chord from the back of the printer without powering off the printer and then reconnect it after 40 seconds back to a wall outlet. You printer will turn on automatically. You might see a message that says "Always use power button to turn off the printer" press ok, this is only a warning message and it does not harm your printer. I am sure your issue will be resolved
Mar 03, 2011 | HP Photosmart C5180 All-In-One InkJet...
PLEASE HELP! jusr bough and installed/setup my new Epson Artisan 710 printer. All the lights keep flashing and I have a message on the printer screen that says: "WARNING - move the yellow material as...
Good Luck & God bless!
Feb 11, 2011 | Epson Artisan 710 AllInOne InkJet Printer
No print
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 25, 2010 | Epson Stylus C88 InkJet Photo Printer
I have a hp 2600n printer. I have just replaced the black print cartridge because the yellow light was flashing and asking me to reorder supplies. Now the yellow light is still flashing the frist box if...
Mar 24, 2010 | HP Color LaserJet 2600n Printer
I just put new cartridges in my printer, won't print
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
All lights flashing on top of HP Deskjet F4235 all in one and pc will not recognize printer.
All lights blinking, Printer not printing
Dec 10, 2009 | HP Deskjet D4160 InkJet Photo Printer
Green light and red light flashing
Dec 09, 2009 | Epson Stylus Photo 1290 InkJet Printer
Print Cartridge is Incompatible
Pleas be certain to remove the clear tape from the cartridge before inserting. Check the contact areas in the printer to ensure there is no tape residue or other material in this area. Go to the HP website and follow the troubleshooting instructions for this problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01082138&lc=en&cc=us&dlc=&product=1119266
Sep 10, 2008 | HP Photosmart 7450 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
198 people viewed this question
Seeker5211
Seeker5211
