Question about Saeco Royal Professional Espresso Machine
Waret Pucks Hi Guys, I'm hoping you can help me with the problem we are having with our Saeco Royal Professional. The machine is a couple of years old and I have been cleaning it regularly as per instructions. Lately, though, the pucks in the dreg drawer have become extremely watery, so much so that they don't even hold their shape and there is lots of water in the dreg drawer. The local service centre advised us to make the grind coarser but this has had no effect. Does anyone have any suggestions how to fix this problem. Thanks, Chris
  • chrispo Jun 04, 2009
    Thank you guys, This was most helpful and seems to have solved the problem. The dreg drawer is no longer awash!
  • 1,089 Answers
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Posted on Jun 04, 2009
    President:
  • 1,618 Answers
They should have advised you to make it finer, imagine your coffee grind as Rocks and Sand. If it is watery then it is too coarse(rocks). Have them adjust the grinder or replace the burrs, if you adjust to a finer setting and still cannot get a great shot of espresso.
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
Saeco royal professional, on display it is shown needs "ventilation", where and how to do this ventilation?
Hi!
I have a saeco incanto deluxe, it was same problem, i just "reset to factory settings"
in the menu, and then the maschine worked again :-)
Oct 23, 2011 | Saeco Royal Professional Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
Hope that helped! Thanks for using FixYa.
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a Saeco Espresso machine that has recently stopped working. The machine is probably 2 years max old. Type SUP016RE, Model: Royal Prof. Has power going to it, however nothing further? Look forward to...
If you open the top cover,1,check the switch on the side is working, 2,check the fuses behind the circuit board is ok,3,under the water boiler there are thermoswitches ...if they are re-settable, push the pins in,and 4,more seriously the circuit board failure which you have to take it to the service center. Hope it helps.
Jan 19, 2010 | Saeco Royal Professional Espresso Machine
Saeco Royal professional is stuck on rinsing and warming up. Although the screen says this, it is actually doing nothing that is apparent. Thank you
Hi
Couple of things will cause this.
You have a bad board or the sensor on the back of the boiler is bad or not making good contact with the board. Its the double green wires, that go from the sensors unless you have one of the new machines that has the double yellow wires.
Jan 09, 2010 | Saeco Royal Professional Espresso Machine
Saeco Royal
Hi Jody,
Nice to help you, hope you get your machine up and running soon:-)
Have a nice day
/Mirran
Aug 19, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal
Hi Jody,
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
I hope you get your machine to work again.
Have a nice day
/Mirran
Aug 18, 2008 | Saeco Royal Professional Espresso Machine
Coffee Grounds
I would try cleaning out your coffee grinder first.
Here is the link to some helpful documents: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Espresso machines and cleaning supplies
Visit www.CeriniCoffee.com
Mar 15, 2008 | Saeco Royal Professional Espresso Machine
Coffee Grounds
Grinder needs to be adjusted or it popped out of its shaft.
Grinding the coffee too fine or the grinder backing up will cause tension between the upper burr and the grind shaft casing.
Once this happens 9 times out of 10 it will relieve pressure by popping itself out of the shafting or worse yet, cracking the shaft itself.
If you open the side of the machine where the brew drive is and you see grinds all over the place, there's a good chance that's what happened.
Needs to be sent out for repair.
Warming up
Machines' heating elements are not heating up. You should have a professional look at it.
Check out www.CeriniCoffee.com
Oct 14, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
703 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
