Question about Welding Tools
No amps i dont seem to be getting any amps from my welder it turns on the fan runs but when i try to stick weld it doesn't run any bead it just seems to burn up the rod and it doesn't change even when i adjust the amps any ideas help
  • walterkarrol May 11, 2010
    Have you been able to run a bead in the past with this welder? What kind of rods are you using? What kind of welder? Is it 110v or 220? Could be a couple things. The rehostat could be shot. Your transformer may not be adusting the voltage/amperage right. Welders are pretty simple machines. Basically, ground, electrode holder, rehostat, and a transformer rectifier. Let me know your experince level also.
  • shane covert May 11, 2010
    need to know make of welder to help you
    President:
  • 1,723 Answers
Have you checked the wire connections for your leads? Give the leads a good look...
Posted on Jul 07, 2009
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln 120v mig welder. makes different noise when running a bead and doesnt get penetration
I WROTE EARLIER WITH A POSSIBLE SOLUTION. I FORGOT TO CONSIDER THE THICKNESS OF THE PLATE YOU ARE RUNNING YOUR BEADS ON. IF THE PLATE IS 1/4"-1/2" THE BEAD WILL PROBABLY BE THIN AND HAVE A HIGH HUMP IF YOU WILL. LOOK IN YOUR MANUAL IF YOU HAVE ONE TO FIND THE SPECS OF YOUR MACHINE FOR THE LIMITS OF THICKNESS RECOMENDED. IF YOU DON'T HAVE ONE I WOULD TRY WELDING ON SHEET METAL,LIKE 14GA. OR 16GA. SEE HOW YOUR BEADS COME OUT ON THIS MATERIAL. FIND AN OLD FENDER TO WELD ON AND SEE WHAT HAPPENS. GOD BLESS AND GOODBYE.
Nov 14, 2010 | Garden
Ive got a handler 135 110v - the weld penetration is very poor - using 030 solid wire with 75/25 gas, I have to run the machine at setting 4 to get a half way decent penetration on exhaust tubing, sheet...
This machine is supposed to be hooked up to a 20 amp breaker all alone, with nothing else running off that 20 amp breaker. Also are you using an extension cord? It is usually not recommended to do so, although I have the same machine and it seems to do just fine. Just make sure you are getting proper power to the machine.
Nov 11, 2010 | Hobart Handler 140 Mig Welder
I bought a 20 amp arc welding kit from canadian tire and dont have an instruction manual with it. i have given it the proper electrical current and amperage and still cant get it too work. looking for the...
20 amps seems like a fairly feeble arc welder--most light models run up toward 80 to 100 amps for a stick welder with wire feed models somewhat lower. Even accidently touching the two leads together should have produced some arcing. You may have a defective unit. Hope this helps!
Aug 16, 2010 | Garden
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
I have a problem with **** inclusion in my welds. I am using 3/32 6013 electrodes on a small AC unit. I am welding 1/8 inch mild steel plates in a 2F configuration. When I start the weld I produce is...
A number of things can cause "****" inclusions, poor Technique, bad fit up, Amperage too low, Electrodes damp---etc. Firstly you are using AC-- Check the Electrode carton for the correct ampage, then check the set up, this is the electrode use AC or DC, most 6013 work better on AC terminal setting dont matter + or -- earth.
If you weave too wide you will loose the fluidity on the weld metal, meaning you will be welding over the ****.
before welding the bead, start and iniciate the weld pause a second until the arc is established then move off.
Jan 08, 2010 | Welding Tools
I have a century 140 welder It does seem to have any power. I'm using .023 wire with co2 gas and with the welder turn up as high as it goes the weld just beads up without any penetration and I was only...
That doesn't sound right. Double check your ground and the tip the wire feeds through -- if it is damaged/worn/burnt it will not transfer full power to the wire. After that, it would be time to check the connections from the transformer to the leads for dirt/loose connections.
Nov 18, 2009 | Welding Tools
Welding Tools Logo
54 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
