Question about Indesit Dishwashers
Indesit d66 dishwasher
The dishwasher cycle does not seem to be functioning properly the dial is just spinning around clicking. the dishes are not getting washed properly .
  • trevisick Jan 03, 2008
    Indesit d66 - all lights on but the machine does not click in and wash anything. Very frustrating any advice gratefully received, have checked for blockage etc and nothing.
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
  • 76 Answers
SOURCE: Zanussi Dishwasher DE6850
Sounds like a heater problem to me, does it go through the complete cycle on its own?
Posted on Dec 03, 2007
  • 105 Answers
SOURCE: indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Posted on Jun 29, 2008
  • 93 Answers
SOURCE: indesit D63 dishwasher dishes not getting clean
Check the rinse aid dispenser is set properly to release a small amount of rinse aid not full and not off but the first click should be fine,then under the bottom rack there are filters remove then and clean them regular,also remember to wash the dishes the same night that you use them ,leaving them over nite will result in the food going hard and you will need a hammer and chizel to remove some dried food,last please remember this is a dishwasher not a food disposal unit you need to rinse the dishes and scrap off loose food before washing
Posted on Dec 28, 2009
Indesit Dishwasher not washing properly or draining
Could be a few problems here. The main one may be the timer. Generally the timer will tell each part to do what it needs to do and when, if it is not closing relays then you get a dishwasher full of dirty dishes. I would also check the pump to make sure it is operating properly. But I would venture a guess at the timer being the main problem.
Sep 06, 2012 | Dishwashers
Will not heat up
it will if the boiler is not up to temp may have dead element in rinse boiler or contactor
Apr 29, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Indesit dishwasher
Feb 23, 2008 | Dishwashers
Indesit D63 dishwasher dishes not getting clean
Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
Jan 23, 2008 | Dishwashers
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Indesit DG 6100
the seal on the top drawer is damaged
Oct 05, 2006 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
85 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
