Question about HP Pavilion a1110n (PX743AA) PC Desktop
Fan runs constantly
The fan on my HP Pavilion Desktop runs constantly and is loud. How can I stop this?
  • j_whitsitt Jun 03, 2009
    I believe it is the main CPU fan. Just within the last few weeks it now runs all the time.
  • freda1960 May 11, 2010
    which fan is it
  • 53 Answers
One reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Posted on Jun 03, 2009
My cooling fan on my HP Pavilion 23 touch screen desktop has the cooling fan running constantly now? Why would this happen all of a sudden?
It's possible that either the chip it's cooling is running hot. The heat sink inside may be covered with dust preventing the chip from being cooled. It also might be dust on the fins of the fan itself causing the extra noise.
You should have it checked out and cleaned to prevent possible damage and fan failure.
Mar 09, 2015 | HP Pavilion Computers & Internet
Loud fan in p6310y
Loud fan noise can indicate overheating issue.
Second hard drive, can go bad, your hp should have told you that once you turn on.
Suggest you run the hp diagnostic tool to figure out if it is hardware issue. See the link below
http://www8.hp.com/us/en/campaigns/hpsupportassistant/pc-diags.html
Mar 25, 2014 | HP Pavilion AMD Athlon II X4 630 QuadCore...
Fan runs constantly on hp pavilion a1530n
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
First clean your computer of dust you could use a fine air blower from a compressor or a can of compressed air whatever you use make absolutely sure there is no moisture in the airlines
if the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm.
But if you hear a loud noise in the fan, i think there's something wrong with it.
I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your computer is operating, you can observe it to know what is really happening.
I don't know what type of fan hp uses on their computers, maybe something is loose already on the fan so better check it or bring it to an hp service center.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
make sure your CPU has thermal paste
your CPU might be getting hot making you computers fan to run consistently
hope this helps
Aug 14, 2012 | HP Pavilion a1530n PC Desktop
My computer runs constantly its loud and annoying
I assume you mean the cooling fan on the CPU, this model uses a smart fan technology, it is meant to spin up faster to provide cooling. If is is doing tis constantly, it means the CPU is not getting adequate cooling (overheating), to check this, remove the side panel, clean all the dust and debris build up from the cooling fan and see if that helps
Jan 22, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
My HP Pavilion a820n pc desktop fan runs constantly. I don't think it always ran this much. Previously ran then shut off then ran. We vacuumed the visible dust. Does this signal a problem? Thank you. ...
Fan is inteligent, has sensor when cooldown is reached auto slow down to fix needs to be replaced,will not hurt anything system running cooler is always a good thing i would run it till it dies unless noise is an issue
Jan 20, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Hp a1110n fan runs most of the time. applied new thermal paste to cpu/heat sink connection, cleaned out dust, problem fixed slightly. What else can I do? Also, could there be a bios fix for this?
Your Fan is Thermal Controlled.... It Will Auto Adjust To Your Temperature..
You Can Rewire THe Fan To A 12 volt Constant Source To Correct The Issue Of THe Fan Not Constantly Running...It will no longer be thermal controlled and it will run all the time... (yellow wires are 12v)
Dec 26, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
My hp pavilion a830n fan comes on constantly and keeps running
I won't say that this is any type of solution but I have never seen a computer or hard drive where the fan didnt run all the time, as soon as I turn on any computer I've ever had the fan runs the whole time it's on.
Mar 24, 2009 | HP Pavilion a830n (PP166AA#ABA) PC Desktop
PC fan running loud & constant
Change fans. Fans do not have a long life.
Dec 15, 2008 | HP Pavilion a1620n (882780664494) PC...
Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Dec 13, 2008 | HP Pavilion a1620n (882780664494) PC...
HP Pavilion a1110n (PX743AA) PC Desktop Logo
1,366 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
