Why is petrol and oil leaking out of the side air filter
If you have fuel comming from the carbuator area it is usually a flooding problem.either you pulled it to many times with the choke on,or the needle inside the carbuator is bad.to fix the first problem, pull the spark plug out,pull it about ten 10 to twelve 12 times.reinstall the spark plug.squeeze the trigger and pull again with saw in full throttle .it should start......second problem is more complacated.you need to rebuild the carbuator.......one more thing that could cause oil and fuel from carbuator is too much oil in fuel mixture.that would be the first thing i would look into......let me know if this helps.........
thanks steve,i,ll have a go at it tomorrow and let you know how i get on.Thanks again Carol.
