Question about Toshiba 27AF53 27" TV
TV Toshiba 27af53 shuts down after a few minutes.
Found some cold joins, and a bad capacitor.. no fix.
Any ideas??
Thanks
Racso
  • 291 Answers
Please give more detail
Posted on Jun 03, 2009
Anyone know how to fix a Panasonic Viera 50" Plasma that powers off a couple seconds after powering on?
tThe diagnostic circuits is shutting your TV down. In most cases the set will shut it down immediately. Apparently your set hasn't shut completely down yet. When you turn your TV on the diagnostic circuits send a low voltage, low frequency signal through all the circuits and depending on how they come back whether the sets powers up to full power. If a problem is detected it will shut down to protect the other circuits. It sounds like you might have some capacitors going bad on your power board. A capacitor that is going bad would let it come on for a few seconds then the diagnostic circuits would see the capacitor getting further out of tolerance and shut the set down. If you are a DYS type person you might want to lay it flat of it;s face and remove the back. A bad capacitor will be bulged out on the top. are Replace capacitors with the exact uf value and if you can go above the rated voltage but never below., If this isn't the problem then it is probably the main board (the board where your cable hooks up to), There are other things that cab causes for this but I would check the capacitors first.
Col. Dana Gillespie
Sep 09, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
The TV will shut off after a few minutes and then cannot be turned back on until you unplug and replug it. Then it will shut off again after a few minutes. How can I fix that? How much would a repair...
it sounds to me that there is a bad capacitor or perhaps a cold solder joint somewhere in the power section of your tv. not sure how much repair would cost, but i will say it's about $50 to have an service tech come out and lok at it.
Aug 08, 2010 | Sharp 27J-S100 TV
Replaced the bulb but tv continues to shut down
radadtoo,
My wd 62525 was acting the same way. Then after a couple days, started flickering and scrambling the picture. I found neals solution # 2 at this link and replaced a few capacitors and 4 hours later, its all fixed!
Here is the link, scroll down to solution # 2 to get an idea of what the caps and boards look like.
http://www.fixya.com/support/t155026-flickering_blue_picture#SameProblemContinued
Any bad capacitor will be oozing out of the top or just bulging on top. And this took a little time and patience to do. Be sure to label all your connectors and screws.. It really helps
Jun 06, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 14, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
The TV shuts off on it's own. Some times it runs several hours before shutting off and sometimes just a few minutes. Thanks
There is a good chance your TV has a bad capacitor or several bad capacitors. Check into getting a new Power Supply Board.
May 03, 2010 | Mitsubishi WD57831 Television
There are about 10-15 small lines on the top of the screen that go horizontally all the way across. These lines distort the picture up there and it is very distracting...any ideas?
The problem is in the vertical section of the TV. Usually one of the electrolytic caps has gone bad. Easy job if youre experienced with board level component replacement.
A shop should charge under $100 to fix.
Nov 23, 2009 | Toshiba 27AF53 27" TV
Unit shuts down after 25 minutes
Solutions?
Hope this helps
Jun 30, 2009 | Samsung LN32A550 32 in. LCD TV
Picture & sound shuts off
Solutions?
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Philips 27RF70S125
your problem is intermittent in the pwer or related circuits have a tech check your tv good luck
Apr 17, 2007 | Philips 27RF70S 27" TV
Toshiba 27AF53 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
