Question about Karcher 2500 PSI Pressure Washer
Removing unloader valve
Karcher K2400 HH. After removing the (2) screws and spring, what do you use to grab the unloading valve to pull it out?
    Scholar:
  • 100 Answers
You can hook it up to the water supply but many times you are going to have to start the unit up to get the unloader to come out. I would recommend putting something over the top of the pump so when it comes out you don't lose a eye. If you still have an issue with it not coming out you are going to have to pour some white vinagur down the cylinder and let it sit for a couple hours, this will breakdown any build-up inside the cylinder.
Posted on Oct 25, 2010
  • Justin  Wisniewski
    Justin Wisniewski Oct 27, 2010
    You have to be very careful if you are using needle nose pilers because you risk damaging the inside of the cylinder as you pull the unloader out
If you can't get it out with needle nose pilers try turning the garden hose pressure on and the water should pop it out.
Posted on Jun 05, 2009
I have a K2400 HH pressure washer. When I started using the machine this year, the pressure would last for a moment or two than quit. When I would shut off the pressure and wait a few minutes and start...
sounds like a weak or worn out unloader valve spring.
MODEL DESCRIPTION PRICE SN-060-216 Pressure SpringKarcher/53323910 $5.90cart.gif
You can find parts online through Karcher or Ebay if you wish.
I hope this helps!
Feb 23, 2011 | Karcher Garden
KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hello there.
If the washer is loosing pressure then it needs to be looked at under warranty, im not sure where the fault would be, but another expert may well know.
If you don't get any suggestions then i would take it back and ask for a replacement or repair.
Hope this helps.
May 09, 2008 | Karcher 2500 PSI Pressure Washer
How do i get the unloader valve out of a karcher pump
If you have a black cap on the top of your pump, the unloader is under that. It is called a spill valve and they sometimes can be a real pain to remove. I usually take a drill and drill a 3/32nd hole in the top of the valve, screw a long screw into the hole and use pliers on the screw to pull it out. You may have to try several times before you get it out. If you don't have a black cap on the top I would need to know the model # of your machine to help.
Jan 24, 2010 | Karcher 2500 PSI Pressure Washer
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
I have a sticking unloader valve in my Karcher 3050. where is it and how do I fix it?
Hello:
Here is a schematic. On page 2.1, part #1 is the unloader valve. You need to remove it and lube it with a very good waterproof grease. Also insure the O-rings are in good shape and the spring action is working.
Jul 07, 2009 | Karcher G 3050 OHR Gas Pressure Washer
How do you clean the unloader valve on a power washer pump?
The unloader valve usually is replaced. I dont know if you can get o-rings for it. But if you want to take it apart, there will be a crown or cap style nut just below the spring. Unscrew it completely and you will be able to remove the spool. There is just a series of o-rings on it.
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K2400 pump is cycling on and off during operation
if this is occers when at rest it could be the pump non retern valve, witch will be just in side tghe machines outlet behine the chemical injector, you will need to unscrew the injector and the valve sits behind it, if this happens when at use it could be a blocked nozzle
Mar 23, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Karcher 2500 PSI Pressure Washer Logo
807 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
