My mouse is an optical mouse (model:MP018-E) One day while operating my computer it suddenly went off but the power supply was O.K. After that I tried to switch it on but It never started. Later I unplugged all the ports except the power cable. When I switchedon, it started. Then I started connecting all the ports. But as soon asI plugged in the mouse port again my PC went off. So I started my PCwithout mouse. After windows appears, when I connected my mouse, againit went out and never started. This is a very serious problem ofoperating without mouse. Please help me out with these. My PC is "PCS ORION", not a very good brand. Earlier the mouse sometimes stops working while playing games. But the CPU never went off. SAMBIT GHADAI. sujatagqi@yahoo.com
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
just installed new motherboard and now receive following message......itunes has detected a problem...
(More)
just installed new motherboard and now receive following message......itunes has detected a problem with your audio configuration. Audio/Video playback may not operate properly. How do I fix this?
Hello, My pc has a problem that says: System Shutdown, This system is shutting down.This shutdown...
(More)
Hello, My pc has a problem that says: System Shutdown, This system is shutting down.This shutdown was initiated by NTAUTHORITY\SYSTEM. Windows must now restart because the Remote Procedure Call service terminated unexpectedly. Then, it counts down 1 minute to restart and I can not do anything because it appears again and again and again How can I fix it?
