Question about SanDisk Sansa E280 MP3 Player
Sana e280 not dtected
When the sansa e280 is put in the MTP mode my  desktop Dell Pc  running Windows XP Media 2005 edition does not detect the device.  However In Msc mode  it does. Called Sansa and Dell for solutions tried checking drivers etc, nothing worked. Was told by Dell whom I purchased it from  to return the player some software problem in it. The quandry is it that it works well on my other pc a  laptop running windows xp in both modes MTP and MSC.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I re-formatted my Sansa e280 and now my computer does not recognize it. I am wanting to transfer music files only, using Windows Media Player.
Try to reset the device and if there is any driver for it, install them before connecting it to the computer.
Feb 28, 2011 | SanDisk Sansa E280 MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
My Sansa e280 will is not being recognized by any PC in MTP or MSC mode. Windows XP is operating system.
i would suggest reinstalling the device or removing the device and letting the computer restart to see if that works if that dont work then use the CD that came with the device finally if that dont work contact Customer Support and see if that helps =)
Sep 02, 2009 | SanDisk Sansa E280 MP3 Player
I've sansa E280 problem is connecting to pc in mtp mode
You can download the software from this page, the options are on the right hand side of this page.
In order to get your Sansa connected, I would change from MTP to MSC and see if your PC recognizes the player then, as it should.
If you go into the settings menu and choose USB Mode and from there you can change to MSC from MTP. If you have one of those models that don't have a USB Mode option, then do the following to change to MSC:
(The model number followed by v2 on the back-bottom require this method) you have to turn it on, put the hold switch on, then hold the LEFT button |<< THEN plug it into the PC.
Apr 23, 2009 | SanDisk Sansa E280 MP3 Player
Can not install MTp device
The best method of installation is to run the installation CD first, and THEN plug the mp3 player into the computer.
If that fails, I would try downloading the MTP Porting Kit from Microsoft's website - I wouldn't suggest this, except that both of your player's are doing the same thing.
-Tha Mp3 Doctor
Feb 18, 2009 | SanDisk Sansa E280 MP3 Player
My sansa media converter did not detect my sansa e280
Set the device to MSC mode (default is Auto) in the USB properties on the Sansa device. This worked for me with a Sansa Fuze on Windows XP running Sansa Media Converter 1.0. Hope this helps.
Jul 17, 2008 | Audio Players & Recorders
you can copy from the my computer open the my computer - open ur device - copy ur images but i am not sure about the videos sorry !!!!
Jan 12, 2008 | SanDisk Sansa E280 MP3 Player
Usb problem
With the device connected, check the Device Manager for errors (red or yellow) on Mass Storage Device and update the drivers on them.
FYI - you need to have Windows XP / SP2 and Windows Media Player 10 or higher for the device to connect to the PC.
You can add to this question for additional support.
Best of Luck.
Oct 10, 2007 | SanDisk Sansa E280 MP3 Player
PC won't detect sansa e280 please help me
I had the same prob with my e280 yesterday and i bought it 4 days ago. I'm using a vista o.s. and i found a way to transfer files this morning. if you are using a vista os you should first set your sansa to MTP mode so that your windows media player can detect your e280 then you can start synching. If you are using XP o.s. there shouldn't be any prob with that but you have to switch to MSC mode. you can find these settings on the setting menu of your e280 then USB can also open the E280 player if you see it on "my computer" there you can transfer the files.don't use your wmp player when you are doing this on vista cuz the wmp player will also synch at the same time and it will synch the same file.
Jun 12, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
105 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
