Question about Acer Aspire 5520-5908 Notebook
Repeatitive confirmation of delete file
When i select any file or even an icon on the desktop, it will display delete file confirmatio box repeatedly
  • panfiloactub Jun 03, 2009
    my keyboard is working very much. the delete key is fine
  • 374 Answers
Just make sure that the delete button or any other button on your keyboard is not pressed sumtimes buttons gets stuck.
Posted on Jun 03, 2009
How to uninstall yontoolog in
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
Feb 26, 2013 | Computers & Internet
How do I delete vGrabber
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. Hope this helps.
b>
Dec 16, 2012 | Computers & Internet
How to solve genuine problem
Welcome to FixYa
There are a number of ways to resolve this issue. The first and simplest way is to download and run a microsoft fix it you can find it here http://go.microsoft.com/?linkid=9763076
If this does not work you can try this
  • Open Windows XP task manager window, You can do it by pressing Ctrl+Alt+Del or right click on taskbar and then select Task Manager.
  • On the Task Manager pop up window under processes tab find wgatray.exe process and then right click and select End process tree option and then select yes.
  • Restart Windows XP in Safe Mode.
  • Delete WgaTray.exe file from c:WindowsSystem32.
  • Delete WgaTray.exe file from c:WindowsSystem32dllcache.
  • Click on Start menu and write regedit.
  • Browse to the location,HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogonNotify
  • Delete the folder 'WgaLogon' and all its contents
  • Restart Windows XP.
As soon as you complete the above steps it will pop up again like Windows is Not Genuine. You can fix even this trouble just follow the following steps.
  • Ignore Step 2 of ending wgatray.exe before restarting to Safe Mode as it serves no purpose.
  • At Step 4, wait on the deletion confirmation dialog box and then open task manager to end wgatray.exe
  • When you are again prompted for a confirmation for terminating the process, align that confirmation box over the delete confirmation box.
  • Press Yes on the Task Manager prompt and then quickly press Yes on the deletion confirmation. (You need to repeat this if you miss it)
  • If you did it quickly then you will be able to delete the file.
  • Step #5 can be missed. I was able to do it without the Step #5.
  • Complete Step 6 to 9 as instructed.
Once you finished the all above steps just follow these steps too.
  • Go to Windows XP Control Panel > Security Center > Automatic Update Settings.
  • Select the third option "Notify me but don't automatically download or install them".
  • Click Ok.
  • Now when Windows Updates icon will appear in the system tray (it will take some time), click on the icon and it will display a list of available updates.
  • This time unselect the checkbox of Windows Genuine Advantage Notification Tool, and click on Download.
  • Select "Don't notify my about these updates again" so it will ignored every time updates are downloaded.
  • From the next time, make sure to check the list of download so that you might not install any new version of this tool.
Apr 30, 2011 | Microsoft Windows XP Professional With...
My computer does not recognize hardware. FYI: Machine hums when I insert a disk.
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Nov 22, 2010 | HP DVD1040e DVD-RAM Burner
My computer will not recognize the dvd1260i burner
6. Click Save.
method.
Regards,
Shami
Oct 31, 2010 | HP DVD1260i DVDRAM Burner
I cant see my dvd/cd drive in"my computer" wndow, but it is visible in "device manager"
6. Click Save.
method.
Regards,
Shami
Oct 28, 2010 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
6. Click Save.
method.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
How to delete messages on the RCA RP5120 dig. voice recorder
This is a transcript from the User Manual you can find here, along with other documets, Faqs, and software for you digital recorder:
http://www.rcaaudiovideo.com/product.aspx?product=393
Erasing selected file:
To delete a file:
1. Press MENU repeatedly to select a folder (A/B/C/D).
2. Press or to select a file.
3. Press ERASE once and DELETE will fl ash on the display.
4. Press and hold ERASE for three seconds to confirm deleting
To avoid accidental deletion of all fi les, make sure you press ERASE only when you are reading the time duration of the undesired file instead of the remaining
recordable time of the player
Erasing all files in a folder:
To delete all files in a specific folder:
2. While playback is stopped, press repeatedly until ALL appears on the display.
3. Press ERASE and DELETE will fl ash on the display.
4. Press and hold ERASE for about three seconds, all files in the selected folder will be erased completely.
Jul 28, 2009 | RCA RP5010 Digital Voice Recorder
How do i delete files from my 512 colby mp3 player
Hey-
First of all, its very nice of you to give away your MP3 player. I am sure he will appreciate it. Now we have two ways of getting all your songs off of there so he can load his own.
The first option is deleting files by using your computer:
1. Make sure the unit is connected to your computer with that nice little USB cord that came with it.
2. Open Windows Explorer on your computer by opening "MY COMPUTER" which is either under the START menu or on your desktop.
3. Next to your harddrive (c:/), you will find a REMOVABLE DISK icon. This is is for your player.
4. Double click the REMOVABLE DISK ICON and use your mouse to select all the music files you would like to delete.
5. After selecting the files, press the DELETE key on your keyboard and then click YES to confirm.
If you rather do it from your player, you can:
1. select the DEL mode to delete files from your player.
2. in the Delete Menu, the following options are available. MUSIC, VOICE, or TEXT.
3. Select MUSIC
4. Your player will list each music file to be deleted one-by-one
5. Select YES to delete the current file being displayed. The screen will display a quick little confirmation that the file has been deleted and then it will move on to the next file.
6. Select EXIT twice to your return to the menu of your now empty Mp3 player. :)
Hope this helps and Happy Holidays!
-TJ
Dec 06, 2008 | Coby MP-C858 MP3 Player
Acer Aspire 5520-5908 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
