Question about Nintendo Wii Console
Internet connection sharing
Hi
this is more of a question than a problem. i am considering getting a connection hub. you plug your ethernet cabel from your modem into the hub and two wires come out of the hub, one into the ethernet port on the computer and another into the wii. this will enable me to share the connection. but i have a question. does this method slow down the internet speeds when using pc or wii and if so how much does it slow down. my internet speed now is 3.5mbps but this changes to around 1mbps during busy times. could you also tell me will the speed be slower on the computer than on the wii and do the speeds only slow down when i will be using them because i have the wii in standby connection mode. i cant get wireless internet where i live so this is not an option.
thanks
    Problem Solver:
  • 9 Answers
Using a hub is fine, but the more machines you connect to this hub or even to your internet is going to slow things down. if your just using your computer and wii i doubt you will see any slows downs.
you speed should not be affected.
Posted on Jun 04, 2009
  • 111 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-78
Posted on Jul 23, 2009
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
1 connected ethernet cable from modem to dynex hub in "uplink port", ran another ethernet cable from laptop to 2nd port on dynex hub and ethernet cable from ps3 to 3rd port and nothing happens. Please help...
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Oct 23, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Internet sharing problem
hi..hmm try to remake new connection and it must all be the same like if your connection is MSHOME the other computer should be MSHOME. if is dosnt work configure your router wan and Lan.
Jul 12, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
How can i connect an additional pc to my rca dcm245 cable modem? i have an ethernet hub.
Hi there.
What you have to do is plug in the Ethernet hub, run the Ethernet cable (RJ45) from the modem to the "internet in" or "internet" socket on the hub, it will the one which is separated from the others.
Then connect an ethernet cable in port 1 to your first computer and a cable from port 2 to your second computer and so on.
If you experience connection problems just pull power from the modem for 30 seconds, plug it back in wait a minute and reconnect.
If you would need further assistance please post back.
Good luck and thanks for using FixYa!!
May 25, 2009 | Thomson RCA DCM245R Modem
Is it possible to have 2 pieces routers to expand the distribution of internet connection instead of using router to hub? what type of cabling should i used to do it? please help thanks
I guess you have a single incoming internet connection and wish it to be shared.
You only require one DSL / Cable router. To share this connectivity you will need Ethernet / Cat5 or wireless.
An ethernet switch or hub will enable you to extend connectivity.
All cable should be CAT5e or CAT6.
Suggest you consider the slightly more expensive switches that have auto-uplink. The negates the need of crossover cables.
Regards B.
Mar 21, 2009 | 3Com Computers & Internet
INternet connection
install drivers for lan card
open run cmd
ipconfig/all
it will show u ur ip adress
then ping to gateway
Jan 27, 2009 | Dell Ethernet Card Network Adapter
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Internet & xbox live sametime Netgear 8-port 10-base-t Ethernet Hub en108
Does the xbox work when connected directly to the internet (not through the hub)? If so, there may be some kind of conflict related to sharing your internet connection between the PC and xbox, and I'd reccommend getting a router instead of a hub.
Feb 20, 2008 | NetGear ProSafe DS104 10-Port Ethernet Hub...
Nintendo Wii Console Logo
143 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
