Question about Network Bridges
Printer connection how to connect printer to computer
  • 244 Answers
Re: printer connection
Hi jatsen,
Please kindly specify what is the brand/model of your printer? Majority of printer it is being installed or connected with the following ports. USB, parallel  ports.
But you need to install the driver if doesn't support by your operating system.
Hope this will be helpful to you.
Best Regards,
Posted on Oct 24, 2007
0 characters
3 Points
Wireless Bridging is used to connect two LAN segments via a wireless link. The...
Wireless Bridging is used to connect two LAN segments via a wireless link. The two segments will be in the same subnet and look like two Ethernet switches connected by a cable to all computers on the subnet. Since the computers are on the same subnet, broadcasts will reach all machines, allowing DHCP clients in one segment to get their addresses from a DHCP server in a different segment. You could use a Wireless Bridge to transparently connect computer(s) in one room to computer(s) in a different room when you could not, or did not want to run an Ethernet cable between the rooms. Contrast this with Client Mode Wireless, where the local wireless device running DD-WRT connects to the remote router as a client, creating two separate subnets. Since the computers within the different subnets cannot see each other directly, this requires the enabling of NAT between the wireless and the wired ports, and setting up port forwarding for the computers behind the local wireless device. Segments connected via Client Mode Wireless cannot share a DHCP server. pictoral In the case in which we are interested, a wireless device running DD-WRT such as a WRT54G is configured as a Wireless Bridge between a remote wireless router (of any make/brand) and the Ethernet ports on the WRT54G.
on Jul 16, 2010 | Network Bridges
Some of my workstation immediately disconnects fron internet
That sounds (apart from a really heavy load on the little router) very much like you are running out of DHCP addresses.
Are your computers set to static or DHCP?
Are they connected via cable or wireless?
What is your DHCP range?
What is your lease time?
If the computers get rebooted i.e. 6 times per day and your default lease time is 1 day, that means that only one computer is blocking already 6 IP addresses per day. 33 computers therefore are blocking 198 addresses, which is almost your entire spectrum from -
So either set them to static IP or shorten the lease time.
Jul 04, 2009 | Network Bridges
Internet Connection won't work
if your router have freeware, like for example you type it on IE, so this mean you are accessing your router, in this method you can see the default connection of your router itself identifying the IP, DNS and gateway address, this time you know what is your exact address going to you PCs...
Jun 18, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Will a computer with 10/10 LAN connect to my wireless LAN?
The 10/100 LAN is a wired connection. If it is connected to the wrt54g through an ethernet cable yes it will see anything on the wireless connection but if you want the computer to use a wireless connection then you will need to get an 802.11B or 802.11G wireless adapter. The wireless adapter does not have to be Linksys but it does generally make thing easier if you use all the same brand.
Nov 29, 2008 | HP AdvanceStack 10:10 LAN Bridge MB...
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Internet problem connection.....
your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Connecting 4200 simens modem to D-Link Router
yes u can!!
however ur going to need a cable called a CROSSOVER cable to connect the modem to the router. you can find this at any computer part supplier near u.
however u MUST connect the computers to the router with normal Straight through cables. plug in n enjoy!
Feb 18, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
There is no utility that comes natively with XP to monitor traffic on an ICS connected LAN. I assume you are not directly connected to the ICS computer, and are running through a Switch or Hub? And you do not have access to this to see how many lines are connected?
If this is the case, you can download and install a packet sniffer and place it within the LAN in front of the ICS computer. It will 'see' all packets traveling across the wire, and report the MAC addresses and IP Addresses to which they are bound. Since every NIC has a unique MAC address (and IP Address), you can see how many computers (NICs) there are in the LAN, and connected to the wire.
You can also use a utility like LanGuard Analyzer to search for all computers on the LAN:
The last time I checked the trial version is fully operational for 30 days.. I use it in my Corporate LAN to monitor all 1000 computers in my domain.
One other thing to keep in mind, since ICS uses the Class C subnet (this cannot be changed), it has a limit of 254 clients that can be attached.. just an FYI..
Nov 21, 2007 | Network Bridges
Network Bridges Logo
165 people viewed this question
Top Network Bridges Experts
john smith
Are you a Network Bridge Expert? Answer questions, earn points and help others
