Question about CMB T43 750 Notebook
Laptop Going off by itself
I just bought a brand new laptop and after a month or so it started going off by itself. I meant "going off" because it goes off like when a tv is switched off. It doesn't have a specific time period to happen this and i dont think its overheating too. Because, even if i use it just once a day and when i turn it on after a few minutes it might go off or it might even stay a whole day without goin off. I'm just desperate to find the problem and fix my laptop. pls i also have a similar problem and i dnt knw wht to do. pls can someone help me fix my problem
  • 53 Answers
What brand is this laptop ? A common problem I have seen on several laptops is overheating. The CPU overheats due to poor coolingit starts performing slowly then the power supply shuts off. The poor cooling issues is due most times to dust or debris accumulaitng in the vents on the sides of the laptop, the fans **** cool air into the laptop, the air is supposed to be routed through the heatsink then the hot air is supposed to come out through another vent. if these vents are clogged by dust or debris the cooling is poor causing the sympton you describe.simply inspect the sides of the laptop and underneath of it and look for vents and dust in them, if you see any of this you can purchase a can of compressed air at staples or office depot and blow it off. It can also be a more serious issue where yuor power supply is failing or maybe the battery is causing this too. in any event if this is abrand new laptop it should be under manufacturer's warranty, take it to an authorized representative or dealr tot ake care of it.
Posted on Jun 03, 2009
Laptop doesn't connect to the internet
If this is brand new, did it come with the window 7 disc? usually all laptops I have come across the operational system is already installed and ready to go. The only thing I can suggest is go online to Lenovo and see if there is an updated driver for windows 7
Mar 09, 2012 | Lenovo Computers & Internet
HI, my coolermaster laptop cooler, the U2 with 2 optional fans have been acting loud. only one fan has been acting up. it makes loud noises while the other one is silent. like a grating noise kind of. cant...
Sounds like the fan is going out. I would take it back to the store and swap it for a new one. Alternatively, if you decide to keep it you can try to put a drop of 3-in1 oil in the center of the fan to prolong and/or fix the noisy fan.
May 26, 2011 | Cooler Master NotePal U2 Notebook Cooler ...
Hello, As i was working on, suddenly my laptop was shut down without any indications. and i tried to start it but it did not. after plugging in the battery charger it started. After that if i remove the...
Looks like you have a faulty battery, since you bought your laptop 4 months ago, I think it is still covered by their warranty. Please try to contact the manufacturer about the possible battery replacement. :)
Some of the things to do/check if the manufacturer requires you to return your laptop to them: 1. Backup all your important files to a different media/storage, like an external hard drive or burn them to blank DVD's
2. You can also tell them that it MIGHT be your charger that's faulty. Either way, they SHOULD check the battery and charger.
Nov 18, 2010 | Acer Computers & Internet
When i turn on my laptop the screen just starts flashing.i only bought the laptop 3 months ago
If purchased as new, it should still be under warranty; don't delay though. If it isn't and there is no sign of video when this is happening, the driver circuitry in the display has probably failed. If there is video, then it can be either the fluorescent backlight lamp itself or the inverter for it.
Mar 10, 2010 | Toshiba Computers & Internet
It has to be the CPU fan. The system board monitors the temperature and if the fan is not working, the temp goes up and the unit shuts down. It may take seconds to heat up or minutes.It is a safety feature. In any case, do not continue using it like that,because it can damage the system board and/or the processor.
If the unit is new, have them fix or repair it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 08, 2009 | CMB T43 750 Notebook
Laptop Will not load past the windows loading screen
BOOT UP INTO SAFE MODE AND LET WINDOWS TO TRY AND FIX IF YOU DO NOT DO THIS THEN YOU ARE GOING DESTROY THE MASTER BOOOT SECTOR ON THE HARD DRIVE AND THAN YOU HAVE TO PAY SOME ONE LINKE ME TO REBUILD THE MASTER BOOT RECORD, UNLESS YOU MAY HAVE ALREADY DONE
CANDYMANGANDY
Jan 29, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Still got my clicking coming from inside my laptop
Usually, the clicking means your hard drive is about to fail. Unfortunately, there is no much you can do about it. Since your PC is 4 months old, you should still be under warranty. Just ask them to replace it.
If they won't, you can get pick a brand new one online at decent prices.
Good luck
Dec 06, 2008 | Compaq Presario Notebook
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Installation problems
I presume you are installing from the CD? Can you select to not boot from CD, and get to a DOS prompt, and then format C: drive? You need to delete the failed installation and start again.
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
T-Comtech Repairs
T-Comtech Repairs
vojvodabudva
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
