Question about Polaroid FLM-323B Television
Cancelling cable We are looking to convert over from cable to hdtv and don't know where to plug in the converter box
    Problem Solver:
That model has an additional ASTC DTV tuner. Plug into the HDTV co-ax input from the DTV antenna.
Posted on Jun 04, 2009
How do I get channel with my Dynex televison?
Yes all over the air channels are now digital. Make sure that your TV is on the correct source. You can get a decent converter box at Walmart for around 20 to 50 dollars
If you need further help, I’m available over the phone at https://www.6ya.com/expert/aaron_a0d6f580814d28b2
Feb 02, 2015 | Dinex Dynex DX-LCD26-09 26 in. HDTV-Ready...
Don't know how to activate HD reception on M and S HD ready tv
Not an HDTV this is an standard thin flat tv,not possible to get HDTV,only get DTV with a converter box for free air,or cable,satalite or telicom signals than not require converter box.
Oct 22, 2009 | Emerson EWF2004 20" TV
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How to install a converter box on the tv
First Converter boxes are a poor economic investment.
Second you have an HDTV. It does not need a Converter box.
Just connect an amplified antenna.
Specs:
Built-in ATSC QAM Tuners - QAM and ATSC tuners included to enable the set to receive Digital cable-in-the-clear signals, as well as digital terrestrial broadcasts. HDTV reception is possible by adding an Optional HDTV antenna
Mar 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Not sure if converter box is needed???
Hello Ann, I will try to help you, well if your for sure about the Manufactur date on the T.V., then yes you will need a digital converter box, also it is suggested to have an outdoor UHF/VHF antenna with coax to attach to your converter box, the old rabbit ears aren't suggested. I hope this helps in getting you prepared for Feb. 19, 2009 when all T.V. stations broadcasting will convert to the new signal. Thank You and Have great day.
Jan 15, 2009 | Sharp 27L-S100 27" TV
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | Televison & Video
Hdtv converter box to vcr
Hi Drtrippy,
If I understand correctly, you are using your VCR for the actual tuning of the TV.
The converter box itself contains a tuner, so you should now receive extra channels available only to an HD tuner. You should try connecting your antenna as input to the converter box. Then output the signal from your converter box to the VCR. Your VCR may then remain connected to your projector.
You may simply think of this as if you are inserting the converter box between your antenna and your VCR, which should be currently connected to receive an over-the-air signal. Remember, as the tuner you will be using is in the converter box, you will need to change channels using the converter box, not the VCR.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
Hdtv function only out of focus
Most have HDTV Converter Box with component, Going to RGB Cmp1 or 2 a composite output cable box will not work.
Oct 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Polaroid FLM-323B Television Logo
117 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
