Question about Canon T90 35mm SLR Camera
The internal batteries have failed on my Canon T90 camera & I cannot find them to replace, Where are they ?
  • Gary Miller
    Gary Miller May 11, 2010
    It's extremely rare to have to replace the internal battery - it is soldered into the circuit under the top cover. What are your symptoms?
  • 23 Answers
Hello!
Southern Photo Technical Service is a Authorized Service Center for CANON.
We do service the camera model you mentioned and the standard cost
to Replace the internal battery, Clean, Lube, Repair and Adjust all functions to meet manufacturers specifications is $98.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
Posted on Jun 04, 2009
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Aug 12, 2013 | Canon T90 35mm SLR Camera
Canon T90 haven't used camera for 6 months, new batteries in camera will not function at all, was 100% O.K. when last used, any ideas please
Check to make sure the replacement battery or batteries are correctly installed. There should be some type of diagram in the plastic or label showing the correct orientation. IF the batteries are correctly installed and the T90 still persists in not operating then remove the batteries and clean all the terminals/connections either with a new rubber on the end of a pencil. I have as much as I hate to admit left batteries in my gear and had to resort to abrasive paper affixed to a new pencil to get down inside the battery chamber to clean the contacts. Also and I hope this is not the case the T90 has an internal battery and if this is dead then I'd suggest sending it to a repair facility. Most service places will clean lub and adjust and replace the battery for about $100.00 and Yes the camera is worth it even today in our digital world
Nov 24, 2010 | Photography
I just loaded up my old T90 after 4yrs of non use. All was well, the display showed mode, shutter speed etc then when I took the first shot I got HELP in the viewfinder and the three EEEs on the lcd. I...
Lin & Daniel,
I had the same problem w/ my T90 after years of not using it. But, the T90 is not dubbed the Tank for nothing. The shutter curtains stucked/stacked because of unuse, especially if you hadn't used it for years.
Here's what i've done to revived it:
I set the shutter speed Tv 500 in Low then hit the carpeted floor while pressing the release button.
Try it my friends and let me know.
http://cyberman9.multiply.com
Feb 27, 2009 | Canon T90 35mm SLR Camera
Canon T90 eee
I don't have a T90 or an FD lens, so can only guess what this means. This is quoted from the T90 manual:
"When you use the stopped-down AE mode with the FD lens, do not push in the stop-down lever with the lens set at the "A" mark. If you do, "E" marks indicating an error will appear to warn you of incorrect operation (EEEE EE in the viewfinder and EEE on the display panel), and the shutter is locked.
In this case, either push in the stop-down lever again to clear the stopped-down AE or remove the lens from the "A" mark. The error display will then disappear."
The stop-down lever is on the lower left front of the camera, and is what is usually now called the "depth of field preview" button. The "A" mark is the setting on the lens for fully automatic aperture control.
Jan 02, 2009 | Canon Cameras
Canon T90
It kind of depends on what exactly the problem is. If the problem is that the speeds are off, then that can likely be remedied without any new parts. It needs a clean, lube and adjust. If its due to the shutter curtains being worn and they need replacing, then there is a possibility that it uses the same curtain as another Canon model and parts can be had new for that model. Worse comes to worse, a parts body can be used for the repair.
Watch the cost of this stuff though. T90s on the used market are selling pretty cheap, so it might make more sense to buy another used and keep yours for parts.
Dec 01, 2008 | Canon T90 35mm SLR Camera
Flash speedlite 300
As long as it's an EX flash, it should be fine. Assuming that a T90 is a Canon...I have no idea about that.
Dec 31, 2007 | Canon PowerShot S5 IS Digital Camera
Canon T90 35mm SLR Camera Logo
1,002 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
