Question about Rosewill R900J 19" Flat Panel LCD Monitor
Dell D630 Laptop starts when it likes.
My Dell D630 Laptop doesn't start always. when power button pressed power light blinks and auto off after few seconds. it occurs regularly. but if i don't use it for long time like 24hours it start as usually and after shutdown problem occurs. i use VISTA.
  • 561 Answers
Chances are your nVidia card is now defective due to a known issue with certain Dell models. The GPU has a clocking issue, and melts down due to heat. BIOS A16 released to combat this, but no real fix except to replace motherboard. See http://www.itexaminer.com/nvidia-dell-hp-sued-over-defective-chips.aspx Even if out of Warranty, contact Dell Support, as they have been known to repair these issues by replacing the motherboards with ATI Video Card models.
Posted on Dec 30, 2009
After relaceing my motherboard dell d630 won`t power up
Double check your pluge and sockets plus if the motherboard is not the original type, check the processor and chipset match.
Nov 24, 2013 | Dell Latitude D630 Laptop Computer PC...
My dell latitude d630 I have pressed and held down the "FN" key and powered the laptop on. Firstly, all three status lights on ones and then stay off. What does this error light sequence mean?
the thing i LOVE about Dell is their completely transparent with their systems.
http://www.solano.edu/technology/data/D630/trouble.htm#wp1311135
Apr 18, 2013 | Dell Latitude D630 Notebook
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
VOSTRO 1320 doesn't turn on
That would leave the processor ic, usually most motherboards do not include that.
May 05, 2012 | Dell VOSTRO 1320 13.3-Inch Laptop (2) PC...
MY D630 LAPTOP WONT START
Remove main battery and try again, next! check power adapter that correct voltage is present, if okay! sub out the ram one at a time testing as you go. Still nothing! It is likely the DC jack in the laptop may have broken free from the laptop, if that is the case dis-assembly down to the motherboard level will be required if resoldering is needed.
Mar 22, 2012 | Dell Computers & Internet
Latitude d630 duo core, 2gb of ram, 80gb, my laptop is well started up but not displaying anything, (black screen)
From a power off state, hold the D key and press the power button see if you get 4 solid colored screens (Red Green Blue ans White) this is the LCD BIST and if you get those colors, then LCD itself is fine. in which case you likely have a motherboard issue
If you get nothing then the LCD is bad and likely needs replacing
Aug 05, 2011 | Dell Latitude D630 Notebook
My Dell D620 will not turn on. Battery is charged and AC adapter is working. When the power button is pressed nothing happens (the power on light on the laptop does not light up). Does this sound like...
I would start with the miniboard that the power button is attached to. If this is part of the keyboard then that is what you need to try first. Replacement parts should be relatively inexpensive as this is a standard business laptop used everywhere. The D series was very popular...you may even be able to use parts from a D610 or a D630. I would start looking for parts on eBay and go from there...
Let me know if you need anything else!
Jun 20, 2011 | Dell Latitude D620 Notebook
I have Dell latitude d630, It is switching on but no display, when I switch on my laptop, its num lock light is on. capslock light works when i use caps button. Power light is on but hard drive light...
Attach an external monitor. Does the external come on? May have to use the FN key + F8 to toggle it between the LCD and the attached monitor.
When you say that the laptop LCD glows a little bit, this makes me think the back light of the LCD has gone bad. If it displays fine on the external, then it is a pretty good chance the LCD back light has failed. If you can attach an external monitor and see something on it, run the built hardware test. This is done from a powered down state. Then press the FN key + Power, this places it into the diagnostic. Follow the on screen instructions. If it comes back with an error code, write this down and compare it to this list at Dell website. http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=14B3819735D6B40EE0401E0A55177ED2
Occasionally, reseating the LCD video cable to the mother board will have a positive effect. Here is a link to the online service manual that explains how to reset it. In the diagram it is labeled #5 It is located under the keyboard.
Aug 10, 2010 | Dell Latitude D630 Notebook
Laptop switches off and doesn't switch on again.
your battery has become weak. you need to change the battery. If the issue persist, you need to service your laptop.
Dec 27, 2008 | Dell Latitude D630 Notebook
Rosewill R900J 19" Flat Panel LCD Monitor Logo
115 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
