I have a audio technica at rmx 64,the tape transport wont stay in the play mode when engaged.I keeps disengageing by itself.This happens in ff and rw mode as well.
  • tehogan Jun 03, 2009
    Would you be refering to the relays that the cam operates when the motor runs? Or the play switch on the board. THANKS
    Dont know yet.
    President:
  • 1,734 Answers
Most probably a problem of the motor control device. Find the full schematic here for free.
Posted on Jun 03, 2009
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
VHS TAPE IS VERY SQUEAKY AND TIGHT AND STOPS WHILE PLAYING
I answered this previously, thinking you were referring to the machine, not the tape itself. See if a different tape (perhaps even different brand) works okay. If not, look at the machine. I have seen tapes go bad, but generally it is the machine (or camcorder).
Jan 30, 2014 | JVC DF420 D-VHS Tape
Sony tc161sd top loading cassette deck.All belts seem present and correct --FF & RW both fine and tape counter. Play mode engages but RH (take up) spool does not turn/operate so deck auto shuts off. Any...
The belts as I have said before are just the tip of the iceberg, there i a lot more that a technician does that you have skipped over. There is a lot of oiling and lubrication of moving parts as well as replacing of idler tires on the decks parts. It needs to be serviced correctly before it will work well.
I am skywave tape deck repair in the Chicago area if you want me to look at it.
Sep 16, 2013 | Audio Players & Recorders
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
C:31:22
It’s a common Sony error code, usually involves the take-up reel, the tape maybe slacked a bit, tighten the tape by doing a FF and RW, sometimes the cassette gets packed to one side, smack the cassette against a flat surface lightly on both sides, do a FF RW and see if that takes care of it, if it only happens with one tape, bless it and bury it, if it happens all the time you may need repair, if you have done a net search you probably have run into mentions of people getting physical to the transport side of the various cams, up to you what you do.
If you have a problem clearing the error use the little reset button under the LCD panel.
Apr 02, 2010 | Sony Handycam CCD-TRV418E Camcorder
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
 Grubhead
Grubhead
