Question about Samsung (SP0411N) 40 GB Hard Drive
Remove the bad sector from samsung sp0411n
It allow to format the drive and i'm using it as a secondary drive. My first drive is segate. But my problem is that when i put some data on samsung hdd it allow to put but when i go to utilize my data from samsung HDD
it show me error that the "data couldn't be read from this location" but
when i put the same data to my another hard disk it's work
  • 1 more comment
  • emdadekh Jun 05, 2009
    No, it doesn't work and I have done this before. if have something new please help me
  • bassass May 11, 2010
    ok did you put windows on that drive? if not ...try this .... right click on the drive in MY COMPUTER and format..hope this helps
  • 696 Answers
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Posted on Jun 04, 2009
How to solve my maxtor 80gb hardisk bad sector problem
You can use LLF Low Level format Tool and make a low level format this take sveral minutes but the most probalby that can fix the problem
Mar 19, 2010 | Samsung (SP0411N) 40 GB Hard Drive
How to clean bad sector
Open My computer, right click drive and select properties, click the tools tab. Now select error checking check now. Select both options (auto fix and Attempt recovery) The check will be done on next reboot. You will get a report as to errors and weather they were able to be fixed.
Dec 05, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Describe your How to solve my Hard disk bad sector Problem
Easy solution would be to format and reinstall your operating system this will mark bad sectors and prevent your system from using those sectors... or follow the sets below if you really want to attempt to fix them
If you are familiar with burning images you can download the Hiren Boot CD image, burn it to a CD and then boot from it.
How to Burn image files http://pcsupport.about.com/od/toolsofthetrade/ht/burnisofile.htm
Hiren Boot CD download http://www.hirensbootcd.net/
Once you have your Hiren CD Insert into your computer and boot from it If the CD did not boot make sure your Boot order in BIOS is set to CD/DVD as the first boot device Generally you press Del F1 F2 or F10 to enter BIOS when the comes first starts to boot Look for Boot Priority or something similar to that and set CD/DVD as 1st device
Ok once in the Hiren CD menu (text menu) goto Hard Drive Tools followed by HDD regenerator This process can takes days and may or may not work
Please comment if you need further clarification or assistance
Thank You
Nov 21, 2009 | Samsung (SP0411N) 40 GB Hard Drive
My hard disk can not boot but works as slave in d ,e, f but not
to make your hard drive bootable it must be active. To be bootable it must have an os on the drive.
Sep 14, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Samsung40 gb harddisk unable to format (SP0411N). But i can read old data. I cant delete anything. cannot delete partition also
Try formatting / partitioning the drive with windows xp setup / installation cd. If you are trying to format or delete partition in windows and its your c: drive you will not be able to do that.
Jul 30, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk data recovery from a bad sector
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jun 30, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Victor
tell me 1st xp installtion had started than stoped,
than ahve a prob for bad sector in booter,
or occured with overheating cause of simultaneously writing.
so try to cool down your HDD.
THNX
May 15, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Samsung (SP0411N) 40 GB Hard Drive Logo
680 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
