Question about Canon PC-940 Black and White Copier
PAPER WILL NOT FEED THROUGH
ONE PIECE OF PAPER GOT STUCK ON THE INSIDE AND WE REMOVED IT AND NOW THE PAPER WILL NOT FEED THROUGH BY THE TRAY ON THE BOTTOM. WE CAN ONLY MAKE COPIES BY INSERTING IN THE ONE SHEET AT A TIME FEEDER.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Check to see if there is a torn piece of paper still in the bottom tray somewhere, its sounds as if there is still a torm piece in there somewhere
Posted on Jun 07, 2009
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
(hp 4000 printer) A piece of paper is stuck between tray 2 and under just before the toner cartridge. I can lift the flap on top of the paper after removing the toner cartridge, but cannot dislodge the...
Probably the way to go is to remove the toner and tray 2.
lay down a bunch of newspapers on the floor (not a rug). The printer is unplugged at this point.
Turn the printer over and lay it down. Take a sheet of paper and fold it lengthwise in quarters.
Manually feed the folded paper into the paper path from the bottom. Push and pull the paper thru
the paper path. The object is to push the small piece out where you can reach it.
It's not the easiest thing to explain. You always want to go in the direction that the paper moves thru the printer. This is why you start feeding from the bottom.
You know that there is a piece of plastic that is above the feed roller for tray 1 that you can pull out to give you more room.
Feb 18, 2011 | HP LaserJet 4000tn Printer
I bought a MFC4770 in May 2010 adn it works well till now. But yesterday, paper jams,then I fixed it. Today even there are lot of paper in the bottom,it always say no paper,but I can feed paper one...
When the paper tray is removed, you should see a plastic piece that dangles, this piece rises and falls depending on the amount of paper in the tray. However, if that plastic piece gets bumped or comes out of its housing, it will sense that there is no paper in the tray. I suggest you look for this piece and ensure that when you manually press it up and release, it falls back down to its original position, if not, you will need to correctly seat it.
-David.
Nov 02, 2010 | Office Equipment & Supplies
The metal plate on the drawer for hp laserjet 2420dn is stuck down how to free this up so that the paper will feed?
remove Tray 2, loock at the bottom on it you will found small plastic piece, push it and voala :)
Tip:
when you remove tray 2, try to push up metal rake a little bit (not so hasrd). Then put back paper tray. If you are lucky tray 2 should be unlocked :)
Good Luck!
Jul 11, 2010 | HP LaserJet 2420 Printer
The printer ask for paper and then OK, but then
a friend helped out. A little piece of paper got stuck somewhere. Thanks for your assistance
Dec 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
IAM USING HP DESK JET F2100 PRINTER MY PAPEROUT LED IS ALWAYS BLINKING AND NOT PRINTING
Possibly it either does not have enough paper in the tray - some printers require about half an inch of paper to work. Sometimes also the switch or feed on the paper try gets stuck, look inside to be sure the paper can feed properly onto the rollers, some printers have sort of a plastic piece that is spring loaded and moves, also look for a switch that may be stuck or if there is any tiny piece of paper that may be inside holding a switch open.
Oct 26, 2009 | Office Equipment & Supplies
Major Paper Jam on Dell 5110
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1. Turn off the printer.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.
If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. *
To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer. Preventing a printer paper jam As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer.
However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring. * If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. * Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. *
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. * Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. * Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 17, 2009 | Dell 5110cn Laser Printer
Broken piece from jammed paper tray
what did you break off?????? let me know so i can help you
Dec 29, 2008 | Brother IntelliFax-2480C Fax
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Paper jam
please give more info. do you see the paper? does it say paper jam when just turned on? does it feed then jam?
Nov 08, 2007 | HP LaserJet 1320n Printer
Canon PC-940 Black and White Copier Logo
93 people viewed this question
old marine
old marine
