Printer prints garbage, no matter what I print
I am using a USB to Serial adapter to be able to print from my laptop to a Canon LBP-1000PS. When I plugged in the usb adapter, my laptop immediately recognized the printer, and installed it automatically. However, no matter what I try to print, the printer just prints pages and pages of garbage. I am at my wit's end. Please can you help?
  • dejoebad
    dejoebad May 11, 2010
    please explain the problem. im not clear to the word garbage :D but i think ur laptop got viruses and make ur laptop OS unstable :D
    Scholar:
  • 84 Answers
I suppose you may have an uncleared printer memory. Right your printer icon and select Open from the shortcut menu. click on document menu and highlighting all the pending files select Cancel to get rid of them. You may have power down the printer to fasten the process. It will take a couple of minutes and sometimes the pc will have to restarted to complete the process. Make sure the all the files are deleted before sending to the printer ok. Also check your printer very well, it could be it has a reset button. if it does, power it on and depress the reset button and that will settle the matter. If it doesn't, then you will have go for confirmed USB cable and adapter. Good luck
Posted on Jun 03, 2009
300 dpi print
go to the cannon website and check their support/downloads
Dec 23, 2013 | Canon LASER SHOT LBP-2900 Printer
Why does Canon LBP 2900 print unnecessary dots
Cleaning blade is faulty, every printer should go for cleaning before and after printing to remove unwanted toner from OPC Drum, in your case cleaning section is not working properly but before that please re-install your printer driver and check for virus also
Rare case interface cable is faulty
Aug 05, 2012 | Canon LASER SHOT LBP-2900 Printer
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
How to redirect lpt print to canon lbp-3000 printer
Here's what you need to do. ON the computer that you want to associate that LPT1 port, you need to know the name of the computer, and the share name of the printer. In this case, I am assuming you have the Canon LBP-3000 physically connected to this system running the FoxPro program.
Step one: Find the computer name. Click on START SETTINGS CONTROL PANEL. Double click SYSTEM. Click on the tab COMPUTER NAME and under FULL COMPUTER NAME, write down the name. Click OK to exit the window.
Step two: Click on START, SETTINGS CONTROL PANEL. Double click PRINTERS AND FAXES. Right click on the Canon LBP-3000 printer and click on SHARE. In the window that opens, click on SHARE THIS PRINTER and take note of the name in SHARE NAME: and write it down. Click on OK to share the printer and exit out of the wizard.
Step three: Click on START, RUN. Type CMD in the box and click OK. in the black window, type NET USE LPT1 \\COMPUTER NAME\SHARE NAME
Follow with RETURN or ENTER and you should be good.
Aug 04, 2008 | Canon LASER SHOT LBP-3000 Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon LBP-800 don't print on a network
I have tried to print with Canon LBP-800 with 2 different print servers and no success. It seems this printer cannot be used with a print server... only with a direct connection to a computer... it supports printer sharing from windows... hope this helps...
Jan 01, 2008 | Canon LBP 800 Laser Printer
130 people viewed this question
jasbo
jasbo
