Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
How do i download a bulletin for a honda GX 610 engine?
Bulletin # 37 is what i'm looking for.
  • 869 Answers
SOURCE: I was told that there
u need to take ur honda to a dealer to get that fixed.
Posted on Apr 19, 2011
  • 3 Answers
SOURCE: hello we have an old Honda
go to honda and enter info
Posted on Jun 26, 2011
  • 653 Answers
SOURCE: Approx how long should the front and rear brake
Take the wheels off and look at the calipers. If there is 1/8 of an inch or less of pad, it is time to replace the pads.
Posted on Sep 11, 2011
  • 3 Answers
SOURCE: honda cr-v stalling
Is check engine light on if so what are codes, does it idle rough or lack power on acceleration?
Posted on Jul 25, 2013
  • 14094 Answers
SOURCE: I need to see a TSB, #TSB Bulletin A-13-021
http://www.myhyundaiforums.com/13-01-021.pdf
Posted on Jun 05, 2015
Lycoming service bulletins
Hi. Lycoming Mandatory Service Bulletin 359 relates only to Lycoming O-235 F and O-235 G engines. These engines have a different power rating than the more common O-235 L engines.
The service Bulletin requires the owner/operator to replace the normal Champion REM38E Spark plugs because they are too HOT for the engine and may cause detonation (pre-ignition) which will seriously damage the engine. The Bulletin recommends replacement of the REM38E plugs with AC-86 Spark Plugs which must be gapped between .018 inches and .022 inches.
Hope this answers your question: Rgs. Bob
May 21, 2014 | Sport & Outdoor - Others
Gx 610 back fires
Is it backfiring. Thru the exhaust or the intake or the carbs
Mar 17, 2013 | V-Twin Horizontal OHV Engine with Electric...
My 2003 honda accord 3.o engine has a code P0706 can u sent me a trouble shoting
Drive Train: POWER TRAIN:AUTOMATIC TRANSMISSION Service Bulletin Number: 11012004 NHTSA Number: 10013662 Model Years Affected: 2005 Date of Bulletin: 04/2005 Bulletin Summary: GOT AUTOMATIC TRANSMISSION DIAGNOSTIC TROUBLE CODE P0706? CHECK THE SWITCH COMBINATIONS. HONDA SERVICENEWS.
Likely yours is the same.
http://www.obd-codes.com/trouble_codes/
good luck and don't forget to vote!!!
Oct 11, 2010 | Honda Accord Cars & Trucks
I replaced EGR valve twice one infact today with dealer part but still the check engine light came on after driving my 2000 Honda odyssey van for 25 miles? any suggestions?
I had an egr code. there is a honda service bulletin out about clogged egr ports. The service bulletin involves putting some kind of sleeve in the port. I just followed the service bulletin to clean out the port, I didn't put in the sleeve or any parts. Seems to be working good for the last six months. It took a couple of hours and some gaskets for the intake manifold.
Sep 23, 2010 | 2000 Honda Odyssey
What is the step by step process for shiming the valve liftersi have a 94 Magna with a lite lifter noise.
I had the same noise you are describing and recently found the solution. Honda has issued a Service Bulletin on the 1994 VF750C Magna regarding a knocking noise from the cylinder head areas. The noise varies as you tip the bike from side to side. It is likely caused by sideways thrust movement of the camshafts which then knock against their holders. The solution is to drill a small hole of precise diameter, length, and location, in each of the cam holders. This allows oil to seep into the space between the end of the camshaft and its holder to cushion the sideways thrust motion.
In the USA, this service bulletin is "VF750C #1". In Canada, this bulletin is "II-1-94", dated September 21, 1994. Your Honda dealer should have a copy of this bulletin.
Click here for an article that explains it in more detail and click here for an image that shows the hole location and depth. I performed this service myself and it fixed the problem! I hope this helps you.
Daniel Stewart
Oklahoma
Jul 09, 2010 | 1994 Honda VF 750 C Magna
M rear heat in my03 envoy blows cold air
There is a service bulletin for poor rear heat on these models.The bulletin number is 05-01-37-002A.The part numbers are 89024885 for 4.2 engine and 89024886 for the v8 engine.It is an auxiliary pump the helps the coolant flow to the rear.The a/c system has to be recovered so I don`t think you can do this at home unless you have an a/c recovery machine.Hope this helps.Good luck.
Feb 22, 2010 | GMC Envoy Cars & Trucks
Wd-62725
I would suspect a faulty Zener or Diode, transistor, allowing dirty DC or AC ripple, to the Caps.. use a scope and have a look. One must always find the cause of why things fail simply fixing the symptoms simply means it will fault again.
Feb 06, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Honda fr600 tiller, trouble selecting gears seems that selector lever hits handlebars making almost impossible to select or change gears
Hello .
Honda has a service bulletin for the units with a serial # 1000001 up to 2001784 for a improved gear shift lever . I will recomend you to contact your local Honda dealer to see if they can get this improvment for your unit .
It's the servicve bulletin Tiller # 5 .
Hope this help
May 05, 2009 | Honda Garden
2001 honda civic: headlight problem
Honda has issued a bulletin that addresses this exact problem. The bulletin number is 04-015. Take the car to your local Honda dealer and mention that bulletin to them. They should replace the Headlight Combo switch under warranty.
May 22, 2008 | 2001 Honda Accord
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
142 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
