Question about Welding Tools
No full arc
Hello, i purchased a lotos 520d welding/plasma cutter the welder works great now i've never used a plasma cutter but i followed the directions and i rechecked everything i have air and i have everything set not sure about the settings for 1/8 inch steel as far as amps and air pressure anyway i can't get a arc i touch it to the metal and i can see spark but still can't get it to arc the cutter is 50 amp.i would really appriciate any help
    Champion:
  • 225 Answers
The spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Posted on Jun 28, 2009
  • David Gates
    David Gates Jul 04, 2014
    I have good ground, now what?
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
CUT50 plasma cutter no arc
Most likely HF spark adjustment needs to be done.
Jul 04, 2014 | Welding Tools
Where can I get consumables for a lotos LT5000D plasma cutter, and is there something else compatible.
You can order them through Lotus Technologies,
http://www.lotostechnology.com/product_p/ltp5000d.htm
Or if you see a name on any of the components like Airco, Tweco, etc, you cold get through your current supplier or you could take them to a local welding supply and see if they can identify them. Chances are very good they simply used something readily available.
Jan 14, 2012 | Welding Tools
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Welding Tools Logo
551 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
