Question about Saeco Easy Espresso Machine
Seaco Easy wont work/Warning light blinking always
My Saeco easy will not make coffee, I have tried pushing in the dregs cup,bypassing both switches,even taken the thing apart, but the red warning light still blinks. I can get steam, but no grind, and no coffee. The brew group seem to be cycling ok? Please help Saeco Easy can get steam, but when I try to get normal coffee, it grinds, get no water and then dumps ground coffee into discard basket. Is very slow the odd time after steam flushing to make a cup.
    President:
  • 1,618 Answers
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Posted on Jun 04, 2009
Saeco Syntia dumping dry ground coffee into dreg drawer without making espresso. **SOLVED** Follow up below.
First, I'm NOT a Saeco technician, But I have worked on similar machines. (I still have one in my garage along with other 'graveyard' coffee machines.) Check your warranty and call for service as there are no customer serviceable parts in this equipment.
*** the following is for information only ***
* I've taken these machines apart many times and found there are a lot of sensors in this unit. Many are very delicate and fault out easily. If you do locate the right sensor, you will still need to locate a replacement. Ordering parts can be a challenge as it must be the correct model (and serial number series). I found out the hard way that not all PC boards are the same as the change functions even in the same model.
* Okay looking around I came across a vid (link below) that shows in detail how to check all the functions of the model he has. You probably don't need to go through the descaling and other checks. The Bean grinder portion is very detailed and not for the faint of heart. But his instructions are clear and should be able to solve your problem. His "No Bean" error was caused by prolonged use without proper cleaning and someone spilt water into the bean cup long ago. I hope to try out his method soon as I never took apart the grinder section completely like he did. I only vacuumed the beans out.
Good luck (to all of us!)
Aloha, ukeboy57
https://www.bing.com/videos/search?q=Seaco+Syntia+no+beans&&view=detail&mid=7D35DEE54A6DBDC3688B7D35DEE54A6DBDC3688B&&FORM=VRDGAR
Feb 08, 2018 | Saeco Coffee Makers & Espresso Machines
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
Diagnostics for saeco Easy
theres a micro switch that gets tripped when theres enough coffee which activateds the dump selinoid
Nov 18, 2009 | Saeco Easy Espresso Machine
Seaco Giro Quick Flashing Red Alarm
Bypass the door interlock with a magnet (the red light will go out when you have the magnet correctly placed above the group). Brew a cup and watch to see how the water is getting into the hopper. Once you know how it is getting into the hopper it should be relatively easy to determine how to fix it.
Apr 21, 2009 | Saeco Odea Giro Plus Coffee Maker
Manual for the EASY SEACO coffemachine
This is giving message to replace the Aqua Prima water fileter. Hold the steam button for 5 seconds until the light goes off to reset the alarm. http://www.saecosupport.com/DisplayMessageEasy.html
Jan 14, 2009 | Saeco Easy Espresso Machine
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Easy Espresso Machine Logo
609 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
