Question about Logitech QuickCam Communicate STX Personal Web Camera
MIKE INOPERATIVE I GET A CODE 1 ERROR ALL THE TIME  THE CAM IS RECOGNISED, BUT THE MIKE DOSEN'T WORK. ANY IDEAS? GRAEME
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 05, 2009
2007 Dakota wont start; fuel gauge reads empty, but I put 5 gallons in it to make sure it wasn't empty. Any ideas?
run the fault codes
reasons for not starting are
broken timing belt /chain
cam/crank position sensors wot working
immobilizer inoperative
problem ignition control module
failed coil/s ECM fault
no fuel pressure ---faulty pressure regulator
faulty pump
gear not in neutral or park
Sep 30, 2016 | 2007 Dodge Dakota
Car has no spark to plugs
run fault codes and look for a cam/ crank sensor problem. Check that the immobiliser is recognising your key
Nov 16, 2013 | 1990 Nissan Pulsar
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Jaguar xj 40 sovereign 1994 error code 17
I'm not a Jag expert, but error code 17 is:
P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
Additional infomation on and cause and possible solutions are here:
http://www.obd-codes.com/p0016
Basically, it looks like you have timing issue. Could be the cam or crank sensor or the timing belt.
The P0017 code would imply that you have at least two cam sensors (V6 or V8). The computer thinks that the B sensor cam is out of time with the other cam and the crankshaft. Depending on the cost and location, you might try changing the cam sensor first. The cost to check or replace the timing belt is probably going to be painful.
Jun 12, 2010 | 1994 Jaguar XJ6
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Error Code 105-E-1 ???
I'M HAVING THE SAME PROBLEM, ANYONE KNOW WHAT THE DEAL IS?
Oct 24, 2009 | Panasonic SDR-H200 Camcorder
1989 Harley Sportser. Ok I just replaced the gaskets in the bottom and top end and side casings, I put all intake and exhaust gears on mark as described in manual, Test fired it and its spitting fuel out...
Run a compression test on both cylinders. They should be within 10% of each other. Since the Sportster has four cams, it is easy to get one of them out of time. I usually install the cams in reverse order, #4,#3,#2, then #1 as best as I can remember. Been a long time since I worked on a Sporty. It is imperative that all your cam timing marks be properly aligned. Cam #1 and #3 align with the marks on the #2 cam and cam #4 aligns with cam #3. Now, cam #1 and #4 look a lot alike and can be confused. Unless the cams are specifically marked which one they are, you have to pay attention to the color code marking position. The color code markings should be near 11 o'clock when cam #1 is timed properly and near the 3 o'clock position on cam #4 when it's time properly.
Sep 21, 2009 | Harley Davidson XL 1200 S Sportster Sport...
My printer won't recognise the new ink cartirdges
Take a hammer to it yet?...Just kidding Just to ask a question are you using genuine ink for the canon or an off brand?
Feb 11, 2009 | Canon PIXMA iP1600 Printer
Logitech QuickCam Communicate STX Personal Web Camera Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
