Question about Samsung YP-K3 MP3 Player
My ipod is not running
As soon as i i power on my ipod ,it gets on but nothing is displayed nor it could be power-off till its whole battery is used...my ipod model is samsung yp-k3.
can anybody help me??
  • 33 Answers
You might have to reset the player. Which will return it to factory settings so that it operates normally.
In order to reset, use a non-sharp object, like the back of a sewing needle, and hold the reset button for a few seconds.
Also update the software and firmware. Connect your device to the computer so that it gets updated. Be sure to reset first.
Posted on Jun 03, 2009
Light not working .how to fix
try all this and fix it. God bless you
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board.
Bad click wheel connection
If the click wheel is not seated correctly, it is possible that the iPod will not boot. Be sure that the bar on the click wheel is completely flipped down to ensure a positive connection.
Jul 30, 2013 | Audio Players & Recorders
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Jan 17, 2013 | IBM ThinkPad T30 2366 Notebook
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
IPOD 2GB Nano display doesn't work
try pressing the reset button on the ipod. if it still freezes, the ipod has problems
Jul 31, 2010 | Apple iPod nano
Ipod not recognized by computer
You have a defected battery and you will either need to send it to apple if it is still under warranty or you need to get another one.
Sep 29, 2009 | Apple iPod classic MP3 Player
Ipod will not turn on
Did the iPod power on before the screen replacement? Most likely you do need a new battery. You can go to www.rapidrepair.com to view free videos on iPod repair and suggestions
Jul 02, 2009 | Apple iPod MA446LL/A MP3 Player
How can I power on and power off my apple ipod a1136 model?
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
Dec 13, 2008 | Apple iPod MA446LL/A MP3 Player
DO NOT DISCONNECT APPEAR ALL THE TIME
Try to do a reset by holding down the menu and select button together till the screen goes blank. The screen will soon pop up with the Apple logo and it will restart. If you can't reset it, then if you know how to take the back off, take it off and carefully prise up the brown lock on the power connector, release the power cable, then put it back and push down the brown lock to lock it in. Put the back on again and start her up.
Nov 20, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod nano screen powered on but nothing being displayed
You can replace the LCD display screen. There are several websites out there that sell the parts and the cover removal tools. It's really not that hard to do, but it runs between $50-100. Type in "Ipod parts" and you'll get several hits for prospective vendors.
Jan 04, 2008 | Apple iPod nano
Ipod cable will not work with the DEH-P3000
Hi, On a slightly different model and only if you would venture to try: with the iPod via cable plugged to the iP-Bus port and the unit powered off but the powersupply on - 1. press and hold for a couple of seconds the Function button (FUNC) or till the clock starts to flash; 2. the arrow keys (left/right) will move you through the different menu settings; 3. the arrow keys (up/down) will move you through the different selection for each setting; 4. look for source, external, AUX, iPod or whatever will be displayed which may refer to an external input; 5. soon as you have enabled/set the AUX, press and hold the FUNC button while turning the unit on. This will save the current setup. Hope this also work for your DEH-P3000. Good luck and kind regards.
Sep 23, 2007 | Pioneer DEH-P3000 CD Player
Samsung YP-K3 MP3 Player Logo
82 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
