Akai LCT2785TA 27 in. LCD Television
Problem for Akai LCT2785TA 27 in. LCD Television
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
By clarefitz400 on Jun 03, 2009
I am trying to use the HDMI port of my LCT2785TA with a Panasonic DMR-EZ47V. The TV shows no signal, not supported, with 480i or 480p in the top left corner. I have tried the DMR with another TV and the HDMI port works fine. Is this TV HDCP compatible? Is the HDMI port compliant with current specs? Where can I go to find out if these two items are compatible. How can resolve this issue? I have tried 2 DMR's, , 2 different HMDI cables. The first cable has gold connectors , 19 pin , latest technology. The second cable had a bandwidth of 5 gig. I could not find a cable labeled ver. 1.1. I have connected the DMR and HDMI cable to another flat panel TV with no problems. I have contacted Akia tech support not getting anywhere. They have stated that the HDMI port would only work with ver, 1.1 or 1.2 cable. I purchased the low bandwidth cable with no success. Akai now says that the HDMI port will accept the signal because it is coming from an HDCP device. Help Help Help ! Thanks! I have connected my HDMI cable to my Laptop and my TV, and keep getting a message saying "No Signal". Can anyone help me to resolve the problem? Many thanks.
Solution #1
posted on Aug 28, 2009
Not Rated)
Rennie436
Rank: Master
Rating: 83%, 3 votes
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Was this helpful?
Yes
No
Popular Solutions for Akai LCT2785TA 27 in. LCD
Questions and Unsolved Problems for Akai LCT2785TA 27 in. LCD
Do you recommend Akai LCT2785TA 27 in. LCD Television?
Answer
Answer
Hi, I have an Akai LCT2785TA LCD tv approximately 2 years old. I was viewing the tv the night before... (More)
Answer
Our Akai tv will not power on and stay on. In the past we were able to unplug the tv and replug it... (More)
Answer
I try to scan for DTV channels and this tv doesn't find any. When I scan using DirecTV receiver then... (More)
Answer
tv wont come on power light is on but nothing else
Answer
My LCT2785TA TV has only one channel now. I cannot change the channel with the controls on the TV... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Akai LCT2785TA 27 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
