Question about RCA F32669 32" TV
Tv just clicks 5 or 6 times
High voltage tries to come up after each click but finally goes dead until unplugged
  • 236 Answers
SOURCE: RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
SOURCE: rca tv model: 32v550t
Maybe the flyback transformer are damaged also the horizontal output transistor.
Posted on May 28, 2008
ladywinn
  • 5138 Answers
SOURCE: Reflowed solder, replaced flyback - still have 5 "clicks" of deat
There is a thyristor next to relay by ac fuse ck to see if it falls off 2 wires holding it resolder back to wirers sticking up its round and sliver .
Posted on Nov 27, 2008
bernardlunda
  • 318 Answers
SOURCE: When I turn my TV on, it clicks on and off 5 times then stays off
first check a switch contacts, that switch has two make contacts in side it. if the switch is okay, then check a power supply dry joints on it.
or a dry joint on the line out put transistor, or a line transformer legs.
Posted on Apr 30, 2009
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Toshiba 57H83 will not turn on
there is some shorting in the main board
Mar 24, 2008 | Toshiba 57H83 57" Rear Projection HDTV
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Tv will not power on. the standby light goes out and the led light comes on but they click back and forth
Ur high voltage is dead,FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Oct 20, 2009 | Televison & Video
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on
Ur high voltage is dead,the FBT,the flyback transformer is dead.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
Jan 08, 2008 | RCA HD52W58 52" TV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA F32669 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
