Question about Xerox DOCUMATE 510 Flatbed Scanner
Invoke Link Fail Error message
After installing OneTouch scanner software, I get an 'Invoke Link Fail' error message when I go to scan a document using the Documate 510 flatbed scanner.
4 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Install Visioneer OneTouch 8920 Flatbed scanner
You need THOSE driver
Download
Rate me as FIXYA please
Posted on Jan 06, 2008
Arius
  • 446 Answers
SOURCE: Where to buy Power Supply for Xerox Documate 510
part number 70- 0497-100, you can buy this around 50$ , visit www.superwharehouse.com and provide this part number...
cheers dont forget to mark this pls
Posted on Sep 04, 2008
SOURCE: my Xerox Documate 510 adds
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
My Ambir ImageScan Pro 820i will start scanning then stop half way and say "scan (not responding)" then error message "generic error"
To help you troubleshoot the issue about unable to scan the document 100%, please follow the steps given below:
- First of all check whether power connection and cable connection to the scanner are correctly connected and it must not be loosen from any end.
- Check if there are any updates available for scanner software to be installed. If yes, then install the updates and restart the computer and scanner once for ready to scan.
If issue persists, it is recommended to contact 'Ambir Support Center' for further assistance from the link given below:
http://www.ambir.com/Support-Ambir
GuruAid.com
Jun 25, 2016 | Ambir Technology Ds820-as -imagescan Pro...
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I lost software for my scanner one touch 7300 usb i need to reinsall it on my pc wadejohnathan7@gmail.com
i have error hp officejet 5610 all-in-one printer :- scanning software could not found, or your scanner is not connected. please make sure scanner and software are properly installed.
Sep 26, 2010 | Visioneer OneTouch 7300 Flatbed Scanner
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Scan to OCR error message
remove all associated driver and scanner software reinstall all the software with the scanner and printer disconnected then rebootit all connected. Try again
Jul 24, 2009 | Brother MFC-9840CDW Laser Printer
Will not do final scan
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Jun 19, 2009 | Visioneer OneTouch 9000 Flatbed Scanner
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Hp officejet 6213 all in one problem
Unistall HP software and install a new set of software
At this link
Jul 18, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Xerox DOCUMATE 510 Flatbed Scanner Logo
2,294 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
