Question about Pentax K2 Film Camera
Pentax K2 Shutter and mirror problem
My K2 somehow has following problems with shutter and mirror: 1. If I press shutter button normally, only the mirror raises up,the shutter could not be released. But if then I press the depth of field button, the shutter releases,and the mirror drops back. 2. If I lock the mirror, it works as usual when we lock the mirror. I am not sure if this is a truly a problem or a particular function of K2. Please adivse me on that, thanks in advance. Ray
    Brigadier General:
  • 3,006 Answers
Without a stripdown it's not possible to give a definitive answer. Clearly the mechnical interlock which prevents the shutter from firing until the mirror is out of the way is not functioning correctly, but pressing the dof button overcomes this.
It's possible that something has broken or worn internally, but far more likely that old dried camera grease coupled with decomposing gooey foam bumpers and light seals has gummed up the workings.
Now that film SLR's are ten a penny and often free on FreeCycle it's certainly makes no economical sense to repair this camera. But it's a real classic and a delight to use so it's worth sending to a professional repair shop for a thorough service just as you would with a classic car or motorbike.
Posted on Jul 04, 2009
The light meter on my PENTAX K2DMD film camera does not stay on when the release button locks in "half way position". i have to push it with my finger to keep the meter working. how can i fix this?
Most cameras of this age work this way as standard, press the shutter button half way to activate the light meter. I dont have a K2 but in the K1000 and KX the meter doesn't stay on when you take pressure off the shutter button. Its probably not broken.
Dec 04, 2015 | Pentax Cameras
The shutter is stuck...all I see is black
Your second curtain is not releasing the mirror to come down.
This happens with weak 2nd shutter curtain tension.
If the wind lever is stuck and the mirror does not come down then the mirror tension spring came off.
May 12, 2010 | Pentax K1000 35mm SLR Camera
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Help with "B" setting
You press the shutter once and that opens the shutter (you do your light painting) then you press the shutter a second time to close the shutter.
When you press the shutter the first time and look in the view finder it will be dark . this is because the mirror has locked its self up while doing the exposure (this is normal) Once you click the shutter a second time the mirror will flop down and you will be able to see threw the viewfinder again.
Jan 24, 2009 | Canon EOS-AE-1 35mm SLR Camera
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
SHUTTER HESITATION
May be the problem is with the lens. Put a maximum aperture say f 22 then press the shutter, if the leaves of the diaphragm shuts and opens fast ten your lens is OK
.If there is any oily appearance between the leaves of the diaphragm then it should be cleaned.
Mar 13, 2008 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME SuperProgram shutter button doesn't release shutter
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: http://mcfaddenphoto.com/camera_manuals/pdf/ME_Super.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | Pentax ME Super 35mm SLR Camera
Open Questions:
Pentax K2 Film Camera Logo
494 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
