Question about Whirlpool Duet GHW9150P Front Load Washer
F01 error code
Washer gives F01 error code and will not run. Help!! I have 4 kids and do several loads daily!!!
  • Anonymous Mar 30, 2014
    What does F01 stand for?
I've fixed Indesit WITE 107 F-01 failure error!
We have the washer like 3 years and the F-01 error kept showing irregularly since one year ago - just after the warranty expiration. Usually unpluging the washer from the power supply solved the problem, sometimes immediately, but mostly overnight. When we moved from flat to country house, the problems frequency slightly increased. Till last couple of days it was still bearable. But in the recent days the error didn't even show up, and the motor was not turning at all. Just the pump was pumping the water in and out, so the program got hanging somewhere. So resolution became necessary. I've contacted tow servicemen yesterday, but none of them answered yet - well it's weekend. But as usually, when you ask for help, you'd find it on your own right after. So I decided to look at it myself.
- unplugged the washer power supply, closed the water
- unscrewed two screws that hold the control panel
- removed the panel - you need the lid to be semi-opened
- (re-conected all connectors to fix any possible oxidation or unpluging - then tried the washer, but problem persisted)
- unscrewed all screws that hold the side cover - only the right one had actually been necessary (when standing in front of the washer)
- unscrewed all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrewed two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver I've cleaned the contact together with the connector and tried the washer - still no effect
- cleaned the black wire connection with the same way
- tried the washer (spinning program) and - voila! It works!
- tried unplugging the black wire and running the spinning program - both the motor AND the pump didn't start
So, it looks to me that the problem was in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor, that caused insufficient voltage and thus a power for the motor but probably still enough for the pump. The randomness of the problem was probably caused by humidity in the room and maybe some more factors - the washer is actually opened from the bottom so when I test the washer more times and see this as a solution, I'll probably cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside. It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer. It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly
So if you are a bit handsome, try this before calling the service. It might help. And also you'll know your washer a bit more.
Posted on Jun 13, 2009
  • harvester_cz Jul 15, 2009
    I am really sorry to say this but my solution for my case worked for like 5 cycles so far. Then we had f-01 again. Now more like a person in need I'll try the advices below mine and will inform you about the results.
  • 10,515 Answers
On the front control the display has a little lock emblem normaly between the options and spin speed buttons you press both buttons at the same time and hold for 3-5 seconds this will unlock the control if the problem reacoures on its on you will need to replace the display control board.
thanks.
Posted on Jun 03, 2009
  • taran_2005
    taran_2005 Jun 03, 2009
    Some more information :-
    My Tech sheet reads F01 is a EEprom Error
    ? Unplug washer or disconnect power for at lease two minutes.
    EEPROM ERROR
    A communication error between the Central Control Unit (CCU)
    and the EEPROM onboard the CCU occurred.
    Possible Causes/Procedure
    ■ A power glitch may cause this error.
    ? Verify CCU operation by running a Diagnostic Test or any
    cycle.
    PUMP DRIVE ERROR
    The pump driver fails to activate.
    ■ Replace CCU board.
    MAIN RELAYS ERROR ERREUR -
    One of the main relays is not working properly.
    ■ The relay might be soldered or always open.
    ? Replace CCU board.
    Good luck and let mre know what you come up with.
    Thanks.
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Door will not open,error code f01
Problem isnt solved, seems like several people are having the same problem with whirpool front load washer with the F01....sad nobody will help you, they want money.....as high priced as those machine are............dont buy whirlpool......
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES F01 ERROR CODE MEAN AND HOW DO YOU FIX
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
May 06, 2010 | Kenmore HE2 Plus Front Load Washer
Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Nov 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin under load
Oct 15, 2009 | Kenmore HE2 Plus Front Load Washer
Error Code F01
Hi there, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Aug 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
He2t F-o1
If memory serves me correctly this is a main control board error. To find out for sure, Remove the lower front panel of the washer. (the 1/4" screws are across the bottom) Just inside that panel is a tech manual. Skip to the error code section. For an F01, the steps should be unplugging it for 2 1/2 minutes (to reset the main circuit board). I would also pop the top cover (the 1/4" screws are in the back side of the top panel) and check for any
loose connections on your main circuit board ( front top, right hand corner) WARNING - Circuit boards are delicate and an static shock could ruin them. Ground yourself (always keep one hand touching the frame of the machine) before touching the connections. Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 error code.If all steps fail, you can contact a local servicer. I only suggest this because I have found there are other things (not printed in the tech manual) that will give a false f01 error code. MAKE SURE THEY PROVIDE A WARRANTY FOR THIER WORK! If you would like to replace the board yourself, they can be obtained from the local appliance parts supply stores or online from the manufacture.
Jul 19, 2008 | Kenmore 46462 Front Load Washer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Error Code F01
F01 is not a valid fault code but if it is displaying that and all the lights are flashing the main computer has gone haywire. Possibly the display board (in the plastic panel that houses the buttons) may be faulty but this is unlikely
Sep 28, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,371 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
